Old 03-01-2009, 11:22 PM
finishlinewrx's Avatar
finishlinewrx is on a distinguished road
First Timers First Pics
Hello
Im Nick from Indiana and i am starting my first build. With some current fab skills and some reading from here i am confident i am going to be able to create something that aleast moves
So being my first build. I have no solid set design plans other than it is 48"x48". Going to just build and design as i go along. Might be the wrong way but i like the challange.
Feel free to jump in if you see something that could be a problem!!
Started with 48' of 2x2x3/16 box tube
Running the crap out of my elcheapo band saw.
Seting up my jig table
First Lengths in to position
So far i have the upper frame in a jig of sorts to help square it all up.
Far tube is leveled off of jig table then all the rest is squared from there.
47" ABBA 25mm rails showed up to help with gantry design
48"x 1" assmembly i got from a old maching at work for use on the Y axis.
(End pillow blocks are at work getting bearing pressed in for the lead screws)
Crappy pic sorry
All i got this weekend, should have the gantry laid out and standing later this week.
I will get pics as i go along
Thanks for looking.
Nick
I Know I Cant Spell..Don't Remind Me
Old 03-02-2009, 02:17 AM
abomb55076's Avatar
abomb55076 is on a distinguished road
Looks good so far! Looks like you are making sure to keep the table nice and level too, that can be the most crucial part. Good luck!
Check out www.Homegrowncnc.com for free CNC machining info for the average joe!
Old 03-07-2009, 04:42 PM
Got some more work done
Laying in some beads
Jigging up the gantry
Gantry standing
Laying out Y Axis
Gantry up and moving with Y Axis mounted
Another View of Y
What you guys think so far??
Nick
Old 03-07-2009, 04:52 PM
FandZ's Avatar
FandZ is on a distinguished road
Looks like you are off to a great start. What are your plans for screws and motors?
Old 03-07-2009, 05:16 PM
For Electronics I Got a g540 4 axis package from Keling.
With the 387 oz motors.
X & Y i have 1/2-10 5 Start form Mcmaster
Dumpster cnc Anti-Backlash blocks
running 2 leads down x with a slave on a axis to help controll racking
Z i am running 1/2-10 single start.
Software i am running Mach3.
And the programmer at work gave me a copy of Autocad and Mastercam on an extra seat they have. (they pay for 5 seats and only use 2) Luck me.
Im just winging it and building as i see fit so we will see how it looks later??
Nick
Old 03-07-2009, 08:03 PM
FandZ's Avatar
Looks like you have enough tools and skills to wing it. I'm sure it'll come out great.
Old 03-08-2009, 09:04 PM
tajord is on a distinguished road
Great going, I can't wait to see how things turns out, keep it up.
A Genius is someone who shoots at a target that nobody sees, ......and hits it
Old 03-08-2009, 10:42 PM
Indoor Work
Can not get Y axis port to work?? motor runs fine if i slave to A and plug in there.
I sent gecko an email to find out if it is a bad driver in the g540
Nick
Old 03-09-2009, 08:31 PM
FandZ's Avatar
Please post your results and how you fixed it. I'm going to be doing a test wireing of mine soon. Is thata keating power supply too? If so it looks like we will have nearly the same setup.
Old 03-10-2009, 01:23 AM
Ended up being a bad pin in my parallel cable. It was shorted out to the solder cup.
Cleaned up the solder connection and everything works great.
Power Supply is the Keling KL-350-48 48v/7.3a
Package i bought is the second listed G540 3axis package
http://www.kelinginc.net/CNCNEMA23G540Package.html
Nick
  #11   Ban this user!
Old 03-10-2009, 08:23 PM
FandZ's Avatar
Yep we pretty much have the same setup. They didn't have this package when I ordered though. I probably could have saved some money. But I'm refusing to add it up to know for sure lol.
Is their anyway I could get you to take a few more pictures of your wiring? See how you branched off the wires of the steppers and which inputs on the PSU you used. I'm horrible when it comes to wiring.
  #12   Ban this user!
Old 03-11-2009, 11:01 AM
http://www.geckodrive.com/upload/G540InitialSetup.pdf
http://www.kelinginc.net/KL23H284-35-4B.pdf
This are the guides i used. Ill get some pictures of the motor plugs and such up as soon as i can.
*Make sure you have a straight through parallel cable to start. That will save you some of the headache i went through.*
Nick
Countdown timers LaserImage General Electronics Discussion 3 01-06-2009 01:50 PM
Displaying Cycle Timers while running? donl517 Fadal 5 10-01-2007 11:12 AM
M.E. Project (pics, lots of pics) skmetal7 CNCzone Club House 2 01-08-2007 04:30 AM
555 Timer not triggering other 555 timers Smertrios General Electronics Discussion 3 10-05-2006 08:16 AM
Looking for a relay controller with timers. Kmed General CNC (Mill and Lathe) Control Software (NC) 3 02-21-2005 01:22 PM
