Old 03-01-2009, 09:04 PM
eloid is on a distinguished road
ATC automatic tool changer
looking for commerical spindles, 1 phase 220v to but used with collet chucks for DIY atc... what is the standard collet chuck used in wood working industry? iso 30 or mk2/mk3 chucks
Old 03-02-2009, 09:13 AM
ger21's Avatar
You can't convert a regular spindle to an ATC spindle that will hols ISO 30 toolholders.
Old 03-02-2009, 06:01 PM
thats the had the impression i had... could not find a economical
spindle manufactures that did?.. anyone have any links or leads?
In the cnc woodworking industry what is the most common chuck type that is used iso30? for the wood working and light metal/ aluminum cnc industry.
assuming there using some type of atc?
Old 03-02-2009, 06:25 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
http://pdscolombo.com/index2.html
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 03-02-2009, 07:46 PM
ger21's Avatar
Probably either iso30 or HSK style. depends on spindle HP and manufacturer.
Keep in mind that an iso30 toolholder with nut and ER32 collet will be close to $200 each, not including the bit. So a set of 5 tools for a toolchanger can easily cost $1200-$1500.
Old 03-02-2009, 09:20 PM
im planing to have my bubby who's a machinist to do all of the diy
machining for the toolholder and the tool changer. It will be a simple tool rack setup, the z axis with engage with....tool holders....
Old 03-03-2009, 09:23 PM
spindle manufactures in offshore?
any know of any other ,anufactures for spindle that offer atc spindles?
Old 03-04-2009, 03:06 PM
cncspear is on a distinguished road
bargain tool holders
FYI. You can save a good bit of money if you get tool holders from mari tool. I have at least a dozen of them and I am very happy with them so far. Albeit, I have nothing to compare them to since these are the first set of toolholders I've ever had, and I bought based on lowest price. But they seem to be of good quality. $100 for a tool holder, $14 for an er collet.
http://www.maritool.com/Tool-Holders...duct_info.html
Old 06-29-2010, 03:01 AM
fidia is on a distinguished road
Try this one. http://www.usovo.de/shop/index.php?c...-Spindles.html
X2 automatic tool changer X2cnc Benchtop Machines 44 07-27-2008 07:11 AM
Automatic Tool Changer Rockwall Tormach PCNC 45 04-21-2008 06:34 PM
I wish I had an Automatic Tool Changer... Chris64 General Metal Working Machines 0 09-09-2007 08:59 PM
Automatic Tool Changer spalm DIY-CNC Router Table Machines 4 07-10-2007 08:49 PM
R8 automatic tool changer N4NV Bridgeport and Hardinge Mills 33 03-05-2007 09:44 PM
