| ok not sure what went wrong, but here goes again....... I am wanting to build a 4 axis, I need to locate some good suppliers that will ship to canada or better yet that are in canada. I have heard alot about a company called Boston Gears, does anyone have the web site address for them? My idea is to use a worm gear assembly for my 4th axis. Does anyone have any ideas or recommendations that would help in making my 4th axis? Is it better to make my own chucks/head stocks and tail stocks or purchase? I don't have a machine shop so the 4th axis would be made out of either pvc or mdf. I think a 40:1 ratio is what I am shooting for using a stepper motor. Or cause I am using a stepper motor, could I use a 1:1 ratio? I want to use my 4th axis to help in making pool cues and as well as doing inlaying on pool cues. |
| Have you thought about what software you will use for this purpose? Pricey, if you want to do live rotary axis milling. It doesn't "go with" the MDF indexer principle ![]() Have you considered a simple indexer for this purpose? Something like a 5C collet closer in a spin index fixture? That way, you'd only have to machine a pocket in each position. Less expensive software required. Just a couple of thoughts for you to ponder. You can purchase gears from Emerson as well: http://www.emerson-ept.com/ I don't know as I would recommend building a gearbox yourself, though. You might be farther ahead to buy a simple indexer (or dividing head) off someone on Ebay.
| Yes Software for true multy axes machining can get expensive. There is a trick you could use for simple stuff. Layout your cad as a flat pattern then scale the Yaxes to messure at 360 units per rotation. At the machine manualy position Y at the center of rotation then unplug the Y axes drivecable and plug it into your Rotary axes motor. Seams to work what I heard from other people. Also saves some money because you dont need the drivers for a 4th axes. You could use the savings on a small rotary table and a chuck. This should give you a head start in converting it to cnc. Good Luck |
| 4020 4th axis problems | little bubba | Fadal | 3 | 06-13-2005 09:08 PM |
| No Encoder Counts On X Axis. Y=OK | murphy625 | CamSoft Products | 5 | 03-08-2005 08:20 PM |
| worm gears, 4th axis | senor J. | DIY-CNC Router Table Machines | 13 | 10-18-2004 11:53 AM |
| 5th even 6th axis? how does it work | ToMMY2ooo | General Metal Working Machines | 10 | 10-04-2004 03:58 PM |
| My Lathe project; might CNC it one day | Stevie | General Metal Working Machines | 86 | 06-21-2004 08:27 PM |
