Old 02-27-2009, 03:09 PM
JeLC is on a distinguished road
Design Advice Needed
Long time lurker but seldom post. I'm building a slightly modified version of the JPGO router. X and Z axis are pretty much complete and I'm now ready to build the gantry and start putting everything together. My question concerns how high to build the gantry. I have a little more than 6 inches of Z travel. I am thinking that the gantry height should allow for a 1" long cutting bit to travel 1/2" below my cutting table height. (that's my own best estimate). That would give me approximately 5 1/2" upward travel of the Z axis.
Is that close, or is there something else I need to allow for, such as limit switches, etc???
Thanks for any assistance!!
Old 02-27-2009, 09:10 PM
stevespo is on a distinguished road
That sounds very reasonable. Just about exactly what I did on my machine. I guess it really depends on what you think you're going to be machining. If it's mostly "flat" pieces, no problem. If you carving 4" thick foam with a extra long endmill, then you'll need some extra height.
In any case, you may want to add some additional holes on your router mounting bracket in case you ever need to shift it up or down a bit. May not be necessary, but it's easy to do now.
Steve
Old 03-02-2009, 02:25 AM
abomb55076's Avatar
abomb55076 is on a distinguished road
Yep, just make sure you dont make it too low and regret it later, I would say about 6 inches is pretty good because theres not much over 6 that you would even waht to try cutting.
Check out www.Homegrowncnc.com for free CNC machining info for the average joe!
Old 03-02-2009, 11:39 PM
Grunblau's Avatar
Grunblau is on a distinguished road
I designed mine so that there was a little over 4" under the gantry. When the Z axis is all of the way down and the router is bottomed out in the mount, the face of the collet is .5 " from the top of the table. I can clamp the router higher in the mount to achieve a greater throw with a longer bit. My Z axis has 6 " of travel.
I had the benefit of a goal to design for which was exactly 4" foam with a long bit. I barely made it....
New Machine Build- Need advice with Z axis design isvflorin DIY-CNC Router Table Machines 3 01-09-2009 07:47 AM
advice needed / to buy or not??? teamjnz General Metal Working Machines 13 08-27-2008 09:48 AM
Semi-newbie looking for some design advice galacticroot DIY-CNC Router Table Machines 15 08-24-2006 07:49 AM
Little advice needed STUG DIY-CNC Router Table Machines 1 01-25-2005 08:11 PM
design advice for a new builder deft DIY-CNC Router Table Machines 9 05-08-2003 08:03 PM
