Here is my design for a PCB / plastic router. I am about 50% done makeing the parts. It will have a working area of 12" x 12" x 5". It is built with 1" x 1/8" square tube and 1/4" plate steel and skate bearings. |
Hi, Why are the gantry sides so high if this is for PCB and I presume plastic sheet? If you don't need the Z hight you are loosing a lot of rigidity as is. Other than that I'm not keen on the bearing arrangement due to the very small contact area on the rail or the axial load on the bearing if plain bearings. Are the rails tube or bar; if tube I thick they will flex to much and sag over time. You did ask ![]() John |
| I wanted the height for milling thick foam blocks. The rails are 1 inch square tube that is 1/8" thick and are only 15" long so I dont think that they will sag. I am not to sure how the bearings will hold up but if they become a problem I could make some V groove bearings. I wanted to used them with that configuration for simplicity. |
| I'd suggest rethinking the bearing/rail setup. As it is, you're putting all weight on the edge of the bearing. You'll most likely get a groove worn into the square tube rather quickly, as well as the bearings actually getting side to side forces from the angle pushing them apart, causing premature failure. For these kinds of setups, most people are using bearings also set at 45deg so they sit flat on the tube. |
| Yea i dont really trust skate bearing slides because they arnt very reliable or accurate and can make the difference between a good machine and a bad machine. Good Luck!
__________________ Check out www.Homegrowncnc.com for free CNC machining info for the average joe! |
| are there still no simple cheap good USB controllers? | lithium | Controller Cards | 21 | 01-16-2009 02:49 PM |
| Build a cheap, SIMPLE, CnC foam cutter. | moreil | CNC Wire Foam Cutter Machines | 51 | 01-04-2009 09:09 PM |
| Simple, cheap servo controll. | Kirbeh | Stepper Motors and Drives | 4 | 01-09-2008 03:33 AM |
| Simple cheap mill | JBV | Mechanical Calculations/Engineering Design | 4 | 11-22-2005 06:20 PM |
| Simple cheap CNC router | mwalach | DIY-CNC Router Table Machines | 7 | 10-28-2005 08:08 PM |
