#49
| I saw the galvanized pipe, but figured the zinc would be harder to get rid of than the black paint. I am nearly at the same point as you, Ed, but I am doing an aluminum gantry which takes me a bit more time to work than doing it in oak. Not that I don't appreciate the looks of oak - you're going to have a beautiful build. I am simply painting my table blue. _______________________________________________ Mach 3, Solsylva 2x4ft. Gecko 540, Xylotex 524's, 1/2 inch 5 start ACME's. |
#50
| Thanks guys. I'm hoping to run it for the first time around the middle for next week. The long axis was a killer, but I don't think the other two will take very long at all. Got those three bearings for the pinion axle yesterday. Neither Lowe's nor Home Depot carried them, so I had to go to a specialty bearing store. The rolled steel axle wasn't very smooth and was a little oversized, so I had to mount it in my drill press and sand along it's length a little. I need a good non-sticky way to keep all this bare metal from rusting, any suggestions? |
#51
CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
#52
For rust prevention on exposed metal, I love the Topcote product: It is also carried at woodworking stores. It think it is some kind of liquid spray on wax, but I applied a single application to the top of my table saw 10 years ago, and still no rust. One can lasts a long time. Don't know if its better or worse for the wear than Carveone's carnuba, but it would be a few dollars more. For surfaces that rub together, which would remove the wax, I've used an LPS product, LPS3: http://www.lpslabs.com/product_pg/co...Corrosion.html which is also used on aircraft. |
#53
| Oooook, been busy since my last post. Fired up the machine for the first time last night, just jogging it. Today I taped on a sharpie and drew some roadrunners. The repeatability was excellent, even with the 1/8" of wobble the sharpie had. Soon maybe tomorrow, I'll mount a dremel on it, and when I'm comfortable with that, its router time. ![]() The max speeds of the 3 axes are approximately: X-700ipm y-300ipm z-300ipm Any more and the steppers started resonating. Any idea why the X went so high and the y wont? I'll get some dampers on them Here's a short vid of it drawing. More pics soon. -Ed |
#54
| Noticing how rough it sounds in the video, didn't sound quite that bad in real life. Still probably need to bring down the speed and dampen the steppers before I run it anymore. Is there anything else that could be causing the roughness? Everything was real smooth rolling and solid before I put the motors on, so I don't think anything is binding up. |
#56
| Putting the machine through it's trials with some 1.5" blue foam. Almost ready to try some pine. A Les Paul guitar top rough carve came out nice and took 8 minutes in the foam, could have ran it much much faster though. |
#57
CarveOne
| Tags |
| solsylva guitar |
| CarveOne's Solsylva 25x37 Router Build | CarveOne | CNC Wood Router Project Log | 428 | 05-15-2010 06:08 PM |
| New Machine Build- Richster's Solsylva dual leadscrew build | Richster | DIY-CNC Router Table Machines | 87 | 04-02-2010 11:52 AM |
| Larger version of Solsylva Overhead Leadscrew CNC Router? | jeffmorris | DIY-CNC Router Table Machines | 5 | 09-23-2008 10:23 PM |
| Len's Solsylva CNC Router Build | bitbanger | DIY-CNC Router Table Machines | 7 | 06-05-2008 06:41 PM |
| My Solsylva router build... | cdsgraphic | CNC Wood Router Project Log | 27 | 06-11-2007 10:46 AM |
