Old 02-21-2009, 09:45 PM
lonnieh is on a distinguished road
Parts not sizing up
Hi all. I am working on a JGRO style build. To speed things up and to have immediate access to a CNC machine, I went ahead and purchased a Zenbot 1216 (edit: Didn't buy it on eBay.) Pretty nice machine for a newbie. However, I am running in a problem, I believe with my RotoZip. I can't seem to get parts to size up correctly as they have been drawn.
Here is what gets me. So I drew a 1"x1.5" rectangle and generated some G-Code with CamBam. When I run the program, I end up with a 0.9725"x1.468"x0.75" rectangle (cut from a sheet of 3/4" HDPE.)
I've been reading up on router runout and it seems like this could be related. I'm baffled, any ideas?
FYI, I am using EMC2 for step generation. I am pretty sure I have everything set up correctly. I am using a config file sent to me by Zenbotcnc.com.
Old 02-21-2009, 09:49 PM
ger21's Avatar
Are you using a 1/16" bit?
Old 02-21-2009, 09:55 PM
No sir, I am using a 1/4" bit.
Old 02-22-2009, 10:16 AM
chester1957 is on a distinguished road
From my experiance run out will cause an inside cut being oversize, as the cutter will cut larger than 1/4". I would check backlash. I made a quick reducer for running 1/8" bits in 1/4" collet and ended up with some run out that caused inside cuts to be too large and outside cuts too small. I adjusted cutter size in cambam from .125 to .135 and parts came out right on. This is only a band-aid till I can get better tooling.
Old 02-22-2009, 10:33 AM
wendtmk's Avatar
Moderator
wendtmk is on a distinguished road
Correct tool offset?
Mark
Old 02-22-2009, 11:59 AM
@wendtmk: I have CamBam set up to use a 1/4" bit, I'm not sure if there are any other configurations for offsets. I am using the free version and not the plus.
@chester1957: Thanks for the info, I'll have to give that a try.
Old 02-22-2009, 02:43 PM
ger21's Avatar
Are you're steps per unit set correctly? If you do a G1 X1, does it move 1"?
Old 02-22-2009, 08:39 PM
Yeah I believe so. I popped an ink pen into the 1/8 collet and drew some things out and measured them with my calipers. Everything looked pretty much dead on. I did notice that my RotoZip (a Rebel) wasn't the tool that the holder was designed for (a RZ10). I trimmed some of the ribs off and now it fits a bit tighter, so it is very possible that the bit wasn't true.
I'm going to try a bit lighter load tomorrow. I live in an apartment building so I have to wait for the neighbors to leave
Sizing PS nate's shop Servo Motors and Drives 2 08-07-2008 06:29 PM
A little help sizing steppers wes Stepper Motors and Drives 1 07-13-2007 11:53 PM
RPC Sizing kochevnik Phase Converters and VFD 10 11-21-2006 04:01 PM
Leadscrew sizing snooper DIY-CNC Router Table Machines 14 09-20-2006 12:17 PM
Stepper sizing callcbm Stepper Motors and Drives 0 12-25-2005 04:47 PM
