| I just received a 3' piece of 1/2 10 1 start acme rod that has a bend in it, and I think it is too much, but would like more opinions before I call the supplier for a replacement. It might be worse if I try to straighten it. I measured it by supporting the ends and placed a dial ind. in the center resting on a metal flat so the threads would not infulence the reading and saw 0.063" of wobble. Thanks |
| Not surprising if it is mild steel 3' of rolled thread. Hardened and Ground, I'd expect better of. Chances are you might get no better, no worse in exchange unless you spec it with additional charges if they offer selective tolerances or straightening services. 1/2" over 3 ft should bend easily. I have straightened 3/4 with a rubber mallet in a lathe chuck advancing it out 1 foot or less at a time, flipping it end for end just past half way out. The stuff is soft enough to make run true on center. Worked goodnuff for my needs on a 3' drill press table jack. But then, it weren't spinning at 1200rpm either. DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
I gave it a try and after a few attempts I got it down to 0.006", which is good wnough for me. ![]() Hager |
| Need Help!- Bent Exhaust Valve | Soultaker696 | Bending, Forging,Extrusion... | 5 | 08-11-2008 10:18 PM |
| Need header tubes bent | RickDLance | Bending, Forging,Extrusion... | 3 | 02-15-2008 09:57 PM |
| Mandrel Bent 4x2 316 wall... | VinceSRC | Bending, Forging,Extrusion... | 3 | 02-02-2007 07:22 AM |
| RFQ: Bent Aluminum Part | lerman | Employment Opportunity | 4 | 04-21-2006 02:15 PM |
| RFQ- Need 3/32" wire bent | CNCadmin | Employment Opportunity | 5 | 12-18-2005 08:32 PM |
