Old 02-17-2009, 09:15 PM
samsagaz is on a distinguished road
Recommended Material to Make an CNC Machine
Hi guys, im planning to purchase 3 Nema34 Steppers with like 800Ncm each one.
im looking some good material to make the machine, i think that MDF will not support the 3kg of each motor.
What Abt Aluminium? Can someone please help me?
THanks in advance
Old 02-17-2009, 09:19 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Those are about 1200 oz steppers. What kind of machine is this? Why do you need such large motors?
How big is it and what kind of drive will it have? What kind of Rapid performance are you looking for? What will you be mostly cutting?
CR.
Old 02-17-2009, 09:30 PM
Thanks for your fast answer.
Machine will be small, i want it for mainly 3 materials.
1 Create small PCB design for personal use
2 Work with brass and aluminium
3 Work with Steel.
i already own 4 LM THK SR25 (New) 4 LM THK SR20 (used 8/10 points)
2 guides for the LM SR25 of 46cm, 1 guide for the THK SR20 of 41,4cm, and 1 guide for the THK SR20 of 41,6cm (2mm of diference).
Maybe i can purchase some small stepper too, but dont know if 600Ncm or small will be OK to work with Steel.
Old 02-17-2009, 09:51 PM
This started out sounding like you were constructing a router. Is it a mill then? Are you going to be using ball screws or Acme for lead screws?
Small is not an answer. What is the work envelope going to be? You could not mill steel very well on a machine made from MDF. It would not be either rigid or accurate enough.
CR.
Old 02-17-2009, 10:01 PM
Well i want to Mill PCBs and route metal and wood.
i will use THK Ball Screw but dont purchase it yet. i want to use the components tha ti already own, so table will be like 46x42cm (its the size of the Linear Guides that i already own)
its the problem i dont know what material to use to get acurrancy enough and be rigid.
Old 02-17-2009, 10:08 PM
Your table dimensions would be 1 5/8 inches by 1 1/2 inches--That can't be right.
You will have to decide whether you need this more for wood/aluminum or steel. You can't have both.
PCB boards need tiny drills and high RPM spindles, Wood and aluminum routers need high RPM spindles. STEEL requires very rigid low speed spindle.
CR.
Old 02-17-2009, 10:59 PM
CR i really dont understand why you say that the table will be 1 5/8 inches by 1 1/2 inches
With the guides that i have i will get like 18 x 16 1/2 Inches!
Ok, i will go with the Wood/Alu ones, and after that maybe later will build the steel one. If i cant work with the three materials in the same machine.
Old 02-17-2009, 11:07 PM
OK then. I guess you meant to write 460 cm by 420 cm.
Those motors will be WAY too big. Maybe N23 270 oz (236 N cm) would be more like it. And you COULD build this out of MDF for wood and aluminum.
CR.
Old 02-17-2009, 11:20 PM
CR.
Ok, will check prices for small motors. Wich design you recommend me in MDF to cut wood? what about brass? that motor will be ok too?
460cm = 4,6 mts = 181 Inches
and
420cm = 4,2 mts = 165 Inches
Old 02-17-2009, 11:34 PM
I'm Not sure about brass on a router. I don't really know if it is feasible. I don't think so though.
Has anybody else ever cut brass on a router?
Approximately 25 centimeters per inch. 420 centimeters is about 17 inches.
CR.
  #11   Ban this user!
Old 02-17-2009, 11:47 PM
CR.
ok, thanks for your support, hope someone can give us some other ideas for now i think that will lower the motors
1 inch = 2.54 centimeters
1 inch = 25.4 millimeters
  #12   Ban this user!
Old 02-17-2009, 11:57 PM
Whoops! I must be tired. You are absolutely right about the centimeters!
CR.
Need to make some stamps. Recommendations for material laka General Metalwork Discussion 1 01-18-2009 02:41 PM
Machine to make RC glider wings HotAir Australia, New Zealand Club house 2 06-14-2008 01:20 AM
Man Vs Machine (Do You recon you could make one?) ynneb CNCzone Club House 11 05-31-2007 07:00 PM
what machine would I need to make this cut? steve knight Commercial CNC Wood Routers 7 08-12-2006 03:30 PM
Noob will pay $500 + material costs for a ready to go jgro style machine midevilone JGRO Router Table Design 14 01-13-2006 07:47 PM
