Old 02-16-2009, 08:17 PM
eloid is on a distinguished road
limit switches
Is there any advanatage in having all your +/- xyza limit switch on more then one input on the bob.. i can see it saving inputs if they all on one input... is it also better to have homes all on separte inputs or can the all be on same input but alone from limits?
im not sure how mach would handle all home switch on one input.....
can someone explain this to me... something tell me they sould be on separte
inputs?
Old 02-16-2009, 10:49 PM
warrenb is on a distinguished road
My machine... Since I know my machine I put all hard limit switches in series because I am limited by inputs on my dual port LPT. It's pretty darn easy to figure out what switch I have hit. There's also the fact that crashing the Z depth makes it pretty obvious what is wrong. Hooking limits in series makes room for free inputs for the homing switches. As far as I know, (I admit this is not hard fact) Mach3 requires seperate inputs for homing switches.
Old 02-23-2009, 04:27 PM
abomb55076's Avatar
abomb55076 is on a distinguished road
If you are able to set up separate limits, do it. I have had a few problems with my limits all hooked up together because if one goes out, they all go out and then you have to look for the problem. Aside from that, I think its nice to have separate ones just because I dont like to have some features that work and others that just "kinda" work. But as for now, Im stuck with one limit.
Check out www.Homegrowncnc.com for free CNC machining info for the average joe!
Limit switches and homing switches AeroKam Open Source CNC Machine Designs 16 01-05-2008 07:56 AM
limit switches terrydullaway General Electronics Discussion 1 09-28-2005 05:37 AM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
