Old 02-13-2009, 07:39 PM
guitarbuilder is on a distinguished road
Advice Please
My plan is to build a cnc router so that I can cut guitar parts. After reading several cnczone posts I see that many build the first cnc to make the parts for the second cnc. Since I learn best by doing I decided to take that same approach. I am going to build a smaller cnc to hold my dremel and or trim router first. I just bought 3 M061-CE08 Superior Electric Slo-Syn Stepping Motors. (ebay) - The spec I am finding are as follows:
1.25 V DC, 3.8 Amps, 200 Steps Minimum Holding Torque: Unipolar - 60 oz-in, Bipolar - 75 oz-in, NEMA Size 23 . Based on this information can someone advise me on a driver type unipoler/Bipolar as well as what I should look for in power ratings. Since this cnc is just a baby step into the cnc world and with the expectation of building a larger machine with nema 34 motors, the least expensive route would be best. I do plan to buy mach3 and would like to be able use it with both cnc setups. I also have some experience in building electronic kits if that would be an option to keep the cost down
Old 02-13-2009, 11:56 PM
CarveOne is on a distinguished road
60-75 oz/in is a rather low torque rating for guitar making and will probably also be slow. 200 oz/in minimum is more common to machines with large enough cutting capacity for solid guitar bodies and acoustic guitar top/bottoms. A lot of them are made with the Solsylva 25x37 machines and larger.
There will be other parts to be made for guitars that these motors will be adequate for in a smaller machine. Mach3 can be configured for use with multiple machines easily enough. So can EMC2 on Linux computers.
Not sure what to recommend for a driver board for these motors but a bipolar driver board would be better as long as the motors can be wired for it.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 02-14-2009, 02:04 AM
ttjarrett's Avatar
ttjarrett is on a distinguished road
Hi Guitarbuilder,
I'm also building a CNC for guitar parts! Here's my build thread:
http://www.cnczone.com/forums/showthread.php?t=71807
After looking into electronics for my machine, I decided to go with a pack from HobbyCNC with their 205oz steppers because it was cheep and was pretty much just what I needed. Their boards may be suitable for your initial set up, but if not, when you upgrade to your larger machine have a look at them.
Thanks,
Toby
If it can't be fixed with a hammer, you've got an electrical problem...
Old 02-14-2009, 06:23 AM
ger21's Avatar
The problem you'll run into is that most inexpensive drives are limited to 2.5 or 3 amps. To get the full torque from your motors, you'll need to supply them with the full 3.8 amps. To get the most bang for the buck from those motors, a Gecko G540 would probably be your best option But since those motors are really too small, going with a complete package from Hobbycnc would probably give you much better performance, and the cost for new motors and drives would be similar to the G540's cost.
Old 02-14-2009, 07:05 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Yep! G540 is the way to go. You can mix or match motors in Keling packages,
http://kelinginc.net/
and his 270 oz in KL23H276-28-4B would probably be perfect. You will also need a Power supply like the $60 KL-350-48 48V/7.3A.
CR.
Looking for a little advice...... CNCwannabe2008 Mentors & Apprentice Locator 2 09-16-2008 03:42 PM
Need some advice surfer13 CNC Wire Foam Cutter Machines 7 02-28-2008 10:52 PM
new need advice kenent1 Benchtop Machines 2 02-21-2008 06:14 AM
I need advice donmorris Milltronics 3 10-31-2007 09:01 PM
New and in need of some advice... well alot of advice! GoonShoes Bridgeport and Hardinge Mills 9 05-30-2007 07:03 AM
