| I haven't tried anything like this myself, but it will work ok with light loads. Heavy loading will cause the edges of the bearings to eventually start digging a groove into each side of the angle and a gap will result that causes looseness in the bearing/rail system. Steel angle rails will resist doing that longer than aluminum rails. The bearing diameter will need to be large enough to provide some clearance to the nut that separates the bearings. The most common method uses the bearings mounted at 90 degrees to the flat sides of the right angle rails for good reasons. This places a flat bearing surface against a flat surface on the rails for maximum load bearing capability and minimum wear on the rails. CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| I tested the idea using skate bearings ,but i cant for the life of me remember why i hadn't gone forward with it ,i think it was due to the side to side slop in the bearings , what worked well was when i bolted the bearings to angle iron which allowed the bearings to come in full contact with the square tubing (like a V ), it was dead solid and slid nicely , then i scraped it and went with v groove bearings instead (less parts) which ride the corners of the square tubing i really like the idea of running on square stock like that , once everything is set properly in place it is solid and simple , my 10 yr old son and i are building a table for him to play with ,after the sucess i had with mine it was a no brainer that its the only way to go with his , this time its homemade v bearings
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| i think it was around 700 rpm on a manual , i made them from aluminum which is good enough for what they are going to do i posted them here http://www.cnczone.com/forums/showthread.php?t=72721
| kind of reminds me of a setup i experimented with where i built a steel cage with bearings coming from every which way and it ran on a large chuck of aluminum channel , for the amount of different ideas i tryed its a wonder i ever finished
| That, is where I'm at. Half way through a build and I keep wanting to try different things. I was this close to building a new gantry tomorrow but now I'm thinking I'll stick with what I have and just improve later. I just have too much to learn than to just redesign everytime I have a bright idea. It's kind of a catch 22. I enjoy the design process and finding solutions so much, I could just keep reinventing the wheel on it over and over. I know I've designed at least 20 different z axis. I haven't built one yet. |
its progression toward success and satisfaction ![]() the design stage is probably the most fun of it all
#11
| I kinda tried something like that - but I was trying on round pipe... almost worked but I gave it up for my latest bearing too - here's a list of all my "rejected" ideas if you're interested http://www.backyard-workshop.com/pro...nc2-ideas.html
__________________ Check out my projects at www.backyard-workshop.com |
| New to forum with a homemade bearing idea for the group | Paulds | Linear and Rotary Motion | 0 | 07-22-2008 11:22 PM |
| New[ish] bearing slide idea | RiseUp | Linear and Rotary Motion | 5 | 06-14-2008 02:18 AM |
| cheap linear bearing idea... | billyinks | DIY-CNC Router Table Machines | 4 | 04-12-2008 03:21 PM |
| new ACME rod bearing nut idea (maybe) | GregMM | Linear and Rotary Motion | 2 | 10-08-2005 05:58 PM |
| Crazy linear bearing idea! | mvaughn | Linear and Rotary Motion | 26 | 08-19-2005 08:07 PM |
