Hello all, and thank you for having such a great website to learn from. I am in the process of building a Jgro design, I will be posting images later. I have been studing other designs. I have a question, which acme screw is the best for speen and resolution. I have read until be eyes are bleeding and I have not found anything on which is the best. I have thought about the 1/2 10 multi start and then I read that the lionclaw design was using a 1/2 8 2 start. I look real good on the flow of what is was doing. Please help Thanks Gerald |
| 1/2 10 seems to be a common size used, you will need to give us a better idea of what you plan to do with your machine, sizes, lenth and so on.
__________________ Join the UK’s machinists community, home to all things related to cnc in the uk. Visit: www.mycncuk.com |
| If you're going for maximum speed, go with a 1/2-10 5 start. Even the 5 start will more than likely give you more resolution than you need. Joe is even trying some 1/2-8 8 stat with apparently good results.
| Ger21 is correct, but I wouldn't get too hung up over calculated resolution numbers unless you are designing microchip manufacturing machinery. If you calculate resolution in the 0.00000001" range it means nothing if your drive system actually has 0.0001" backlash. Assuming that you actually can measure 0.00000001" backlash in your system, it means nothing if you are cutting wood, MDF, Depron, aluminum, etc. if the surface texture of the cut material actually has 0.0001" variances at any two points of measurement. See, nothing to worry about. For DIY wood cutting machines 8 start lead screws are just fine. ![]() CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| How do you mount a lead screw/lead nut? | jbluetooth | DIY-CNC Router Table Machines | 2 | 12-01-2008 04:10 PM |
| Belt vrs. Ball Screw vrs. Lead Screw | stevesplanes | Linear and Rotary Motion | 7 | 01-09-2006 11:23 AM |
| New technology.... old debate.....ball screw vs lead screw | trubleshtr | Linear and Rotary Motion | 1 | 08-15-2005 08:42 PM |
| Ball Screw or Lead Screw? Which is Better? | ljoe1969 | DIY-CNC Router Table Machines | 4 | 07-28-2004 08:49 AM |
| Ball Screw and Lead Screw | ljoe1969 | DIY-CNC Router Table Machines | 9 | 11-21-2003 08:06 AM |
