Hi guys Im basically thinking of starting my first CNC project, i want to make a cnc based pcb engraver. At the moment ive just been doodling ideas down, and trying to come up with a spec and anticipate any areas which will require particular planning/cunning. I have worked for a kitchen cabinet maker and done a lot of work with MDF and drawer rail systems etc. At the moment im thinking about a fixed gantry system with a moveable table I want the machineable area to be roughly the sise of an A4 sheet of paper (210 * 300 mm roughly) as that is the largest copper clad board i can get my hands on easily I want to build the axis as cheap as possible, investing in the motors and drivers, so materials im considering are : 18mm MDF M6 threaded rod (not sure on pitch yet, advice appricated) Kitchen drawer slides (various types) Although accuracy is important, i dont need to be able to route PCB tracks between pins of ic's, and if i do, wire jumpers or double sided board will be sufficient, or i can develop one with chemicals ad resist (I mostly make Power supplies and simple < 150 compnent boards) The router i will be using is a dremal clone from black and decker Questions & Areas im struggling with ideas for: to come up with cheap easy to make and reproduce accuratly in wood, bearing system for the lead screws have seen quite a few people using plastic for the leadscrew nut (one driving the table/axis) could i use aluminium? as i have a large block of it at home and access to a mill to machine it..., or better off with plastic What sort of sise/voltage steppers will i need? obviously i dont want to reinvent the wheel so any ideas and comments greatfully received Tim Chubb. |
| Hi take a look at this link, he has some intresting solutions to homemade cnc stuff. http://www.angelfire.com/az2/proff/index.html |
| L297-8 PCB - who is interested / anyone sells them? | RomanG | Open Source Controller Boards | 22 | 10-26-2005 01:42 PM |
| Pictorial Guide to Making PCB (DIY) | abasir | General Electronics Discussion | 31 | 08-17-2005 11:14 PM |
| Having trouble cutting aluminum sheet | fastturbovet | General Metalwork Discussion | 40 | 06-14-2005 10:33 PM |
| PCB manufacture | skippy | General Electronics Discussion | 37 | 04-13-2005 11:05 PM |
| PCB engraver / mini-cnc machine | NickLatech | General Electronics Discussion | 3 | 12-26-2004 07:05 PM |
