My first CNC build. I'm going to build a desktop CNC mill but as my country (Iceland) has collapsed financially i find my self not being able to order things online without paying an arm and a leg. I have about 1 month to do this. My plan: A 3 axis, 4 would be a +, mill with a milling-area of about 300x450mm (A3). I got some motors from 2 old Okidata dot-matrix printers, don't know if they will do the trick so i got a large HP laser printer/copier that i have yet to take apart. I got axes to a metal shop. Timeline: week 1 - Gather information and free parts. Do a lot of price checks. week 2 - modeling and design. Spend money :'( week 3 - General build / Partial assembly. week 4 - Assembly and testing. week 5 - Make something and drink beer (in that oder) If you guys have any ideas or tips or designs you think would be good please let me know. |
So i riped apart the small laser printer and it has a lot of good parts that may be utilized. The only thing i am not shore of is the electronics. The electronics i'm not that good at. Here is what i got from the printer. photo 0: Power supply Pinnout (1-10) - (1,4,7,8)=GND. (2,3)=+5V. (5,6)=+24V. 9=NC. 10=HEAT_ON photo (1): power inlet on/off switch. photo (2): LED's and button. photo (3): The motor Type BH55FT15-04, DC 24V, 15W, 1500r/min, no.2202, L001 5411, Japan Servo Co.LTD made in china has a 5pin input. photo (4): Motor underside photo (5): Control board i guess pinnout from closest to sticker clockwise 8pin=PSV, 2pin=cover, 2pin=THM, 8pin=HVPS, 6pin=sensor, 2pin=smart, 2pin=fan, 5pin=motor, 3pin=toner, 2pin=SOL, 2x12pin=?? something from the usb or paralellport. photo (6): metal casing whats inside. photo (7): Input signal board in a metal casing. has the 12pin out, 6pin= sensor's, 2pin=single sensor The question is: Can i use this stuff in any way. Is the motor any good. |
| Take a look in my thread. The rails I built are very cheap and very sturdy. I'd say around $8 to $10 per rail and roller assembly. I have video of the Y axis up rolling smoothly with over 100lbs on them. I should have video of the X this weekend. I'll be putting the gantry through some paces this weekend too. I'm sorry I can't be of more assistance on the electronics and such. I'm still learning. Also if you do look at my build thread don't try to make the table portion. That was a lot of work. If was to start again I'd go in a different direction for the table. Not that I regret it, it is very strong, but I could have gotten just as sturdy of design avoiding aluminum angles. That was a pain.http://www.cnczone.com/forums/showthread.php?t=71949 |
| People do wood with a lot of success but I don't see the point. If I'm going to invest the time, I'd want it to be the strongest it could be. I'm probably going to put a wood top over my table for dry cutting and make an aluminum table top for wet cutting. That is, If I don't immediately start on my second one as soon as this one is finished. |
| I need help. now i have gathered a a bunch of electronics and motors from different printers, scanners and other stuff. because i have a lot of small rods i changed the scale of the cnc mill to just the size of an A4 paper so that i could use the stuff. But i have no clue if i could just slap together any motor control board and use it with any of the motors. I'm not a very electrically inclined person, i can solder perfectly but to design a circuit board not anytime soon. here are the motors i have on my desk and i remind you about the photos below that i already posted. Please if you have some advise for the electrical noob i'll take it all. Last edited by MStef; 02-17-2009 at 06:55 PM. |
#11
| Pic 1-2 is obviously a stepper motor because it says so on the label. It is barely large enough to move a light weight scanner head. It looks way too small to power a CNC router where there will be heavier components and cutting forces to contend with. The other pics look like DC motors. They might have circuitry to maintain approximately constant speed, but they would not be accurate or strong enough for CNC. It looks like you might need to spend some money for real motors. I have never had much luck finding surplus stepper motors with enough torque to run a CNC router. Really good ones can be purchased here for around US$50. Not sure what is available in Iceland. Good luck on your search and don't be too discouraged if everything takes longer than your original 4 week plan. I have been working on my machine part time for 2-3 years and it has just recently started being useful. Steve |
#12
Hey there, You can get pretty cheap small steppers (e.g. $30) from Keling. You can also get pretty cheap complete kits from Probotix. CNC4PC also has cheap electronics, and the new Gecko G540 is pretty cheap as well. HTH, Chris.
__________________ List of parts sources for CNC builders - http://www.CNCsources.net Dyna Mechtronics 4400C Conversion - CNC bed mill w/toolchanger to Mach3 conversion - http://www.cnczone.com/forums/showthread.php?t=50787 |
| Easiest way to learn Surfcam? | rbest27 | Surfcam | 25 | 04-15-2011 08:28 PM |
| Suggestions on easiest kit to impliment. | cpcapace | DIY-CNC Router Table Machines | 4 | 01-27-2009 10:41 PM |
| What's the best/easiest to use CAM package for Solidworks? | squale | Solidworks | 23 | 12-02-2007 12:43 PM |
| Best / Easiest / Cheapest PCB milling software | scot101 | General CAM Discussion | 2 | 11-26-2007 12:32 PM |
| Easiest 3D drawing program | NeoMiller | Autodesk Software (Autocad, Inventor etc) | 1 | 10-23-2003 05:56 AM |
