Old 01-31-2009, 11:24 PM
ticica's Avatar
ticica is on a distinguished road
My first build - KRouter
None of my family members was particularly impressed, so I decided I'd give it a shot here...
All three axes are THK KRxx elements. While not inexpensive (each of the KR elements can cost from $100 up on eBay), it is fairly easy to build.
I only made 10 parts to put it together:
Nema 23 adapters for Y and Z axes (X came with a motor and a coupling)
Y to X attachment plate
Z to Y attachment (an angle block with some holes)
2 parts for the spindle holder (the spindle assembly was bought on eBay)
4x aluminum extrusions for the base
Well, it cuts plastic (the video shows a 0.3mm depth of cut, 1/8" end mill). It probably could do some engraving or PCB routing, as well. I did not measure deflection, but it feels much more rigid than I originally expected.
Cheers,
Ivan.
Old 01-31-2009, 11:43 PM
jalessi's Avatar
jalessi is on a distinguished road
Thumbs up
Ivan,
Is there anything supporting the X axis on the opposite end or is it cantilevering over the span?
It looks like its cutting the circle pretty well.
Jeff...
Old 02-01-2009, 08:56 AM
vlmarshall's Avatar
vlmarshall is on a distinguished road
Thumbs up
Interesting build, nice work. Start making parts!
Old 02-01-2009, 09:26 AM
ticica's Avatar
Jeff, the X axis is bolted to the base. I guess you are asking about the Y axis (the one holding the Z axis). That one is not supported on the other side. I wanted it to be able to engrave on the edges of large sheets of wood (or picture frames, for example), so I left one side open...
Thanks for the comment, vlmarshall.
Old 02-01-2009, 10:07 AM
vlmarshall's Avatar
Nice idea. Does it deflect under the weight of the spindle?
Edit: Nevermind, I just remembered you saying "I did not measure deflection."
Old 02-01-2009, 10:29 AM
cheetahcnc's Avatar
cheetahcnc is on a distinguished road
Cool setup! A large commercial Biesse B7 CNC Router uses the cantilever design, similar to what you are doing. It sure keeps the costs down, but the large part workability is even better.
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
NEW BUILD: PVC as a build material Smiler DIY-CNC Router Table Machines 12 11-13-2009 04:57 PM
New Large Table Build in Houston, TX (Build Log) anitel Plasma, EDM and other similar machine Project Log 12 12-30-2008 02:45 AM
My first build jdholbrook CNC Wood Router Project Log 7 06-23-2006 11:01 PM
