I am starting a 4' x 8' CNC router build and am about to purchase some components today. I was hoping at least one person could answer my psu/stepper question? Im looking to purchase 3 x #RS34-960 Looking for a power supply. If I run the steppers in parallel I have yet to find a 110v PSU that will supply at least 14 amps. Do I just have to run them in series or uni then? Thanks! |
There are lots of 110V PSU (I'm assuming 110V input, you dont say what output) on the market that will do the job, for example this or Keling do a 35v 15A supply (KL-3815). But how do you know you need these motors? Do you need that much torque? Could you use smaller motors? What driver will you use that can handle 7A?
__________________ If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com |
| If you want the most powerful motor for the buck, the $129 Keling KL34H2120-60-4B 1200 ounce dual shaft is the way to go. It is a 4 wire motor wired Bipolar Parallel INTERNALLY. If you only need the single shaft version, it is $10 less. http://kelinginc.net/KL34H2120-60-4B.pdf Since its best operating Voltage is 78V, it will run very nicely at 72V with the $189 KL7220. http://kelinginc.net/KL7220.pdf http://kelinginc.net/ I know this for a fact because I run the exact same motor and power supply with a 203V. CR. |
| CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| Real quick Gecko/stepper question | idtkid | DIY-CNC Router Table Machines | 4 | 01-27-2009 10:22 AM |
| Quick Stepper Wiring Q | kawazuki | Stepper Motors and Drives | 1 | 08-21-2008 11:11 AM |
| Quick Question on stepper motors | cspearsall | Open Source CNC Machine Designs | 3 | 06-28-2006 05:51 AM |
| quick stepper electronics question | keebler303 | General Electronics Discussion | 4 | 03-31-2006 07:40 PM |
| Quick servo vs stepper questions | Hack | General Electronics Discussion | 5 | 08-05-2004 01:48 AM |
