Hello. I have just finished putting together my 3 axis cnc. Well the basics. I have not purchased the motors or 3 axis cnc board. My unit is made from mdf and is roughly 24 " x 18 ". So it's pretty small. My question is for hobby cnc ez kit. Does it have easy to use instructions to wire, and then enter in the needed parameters for the mach software? |
| The Hobby CNC kit has very good assembly instructions and all connections are well marked. Mach3 motor configuration varies due to stepper motor size, type ,screw starts, threads per inch etc... Mach3 home and limit switch configuration also varies due to type of switches and if you use a switch for limit and home or separate switches. Each machine will have its own unique setting in Mach3. There a wealth of information here as well as the Hobby CNC User Forum. Between the two you will get plenty of help so there is no need to be worried. Jeff... Last edited by jalessi; 01-27-2009 at 10:46 PM. |
| TPI = Turns Per Inch a 20 TPI = 20 turns of the rod per inch of travel |
| Easiest way to learn Surfcam? | rbest27 | Surfcam | 25 | 04-15-2011 08:28 PM |
| What's the best/easiest way to learn CNC machining? | squale | Teachers Hang out | 4 | 02-28-2009 01:30 PM |
| What's the best/easiest to use CAM package for Solidworks? | squale | Solidworks | 23 | 12-02-2007 12:43 PM |
| What is the easiest plastic to machine? | pced | Product Announcements & Manufacturer News | 12 | 01-22-2007 08:49 PM |
| Easiest 3D drawing program | NeoMiller | Autodesk Software (Autocad, Inventor etc) | 1 | 10-23-2003 05:56 AM |
