Old 01-26-2009, 01:56 PM
fahque99 is on a distinguished road
Gantry Vs XY table
What are the pros and cons of a gantry vs a xy table with a ridgid Z axis?
This would be for a small setup ~15 inch table
Old 01-26-2009, 02:22 PM
Al_The_Man's Avatar
It all depends on what the intended purpose is or used for, if only 15" table, the rigid set up might give you a wider usage, the gantry method generally does not have the rigidity for decent milling.
open table vs closed-table gantry setups nicanor76 DIY-CNC Router Table Machines 2 04-21-2008 12:35 PM
Moving gantry or table? igolfat8 Commercial CNC Wood Routers 1 03-10-2008 09:24 AM
Movable table vs gantry aggie_67 DIY-CNC Router Table Machines 16 12-20-2006 06:11 AM
Gantry or table? skaha DIY-CNC Router Table Machines 5 10-11-2006 11:06 PM
Gantry or Table?? jetstuff DIY-CNC Router Table Machines 6 02-16-2006 08:39 AM
