Old 01-24-2009, 08:14 PM
eloid is on a distinguished road
charge pump
what is it why do u need one?
Old 01-24-2009, 09:43 PM
sparkness is on a distinguished road
Charge Pump is an electronic circuit, the term here is used to describe the connection of a PC to a CNC controller. the circuit connects to a parallel port and monitors a pin for a frequency. If it is present it will allow the controller to move the motors. if it is not present the motors do not move. It is a safety built into a breakout board to prevent any movement of motors during start up of your CNC machine and PC and software. Once the PC has booted and the software is up and running the circuit will now let the controller move the motors
Old 01-25-2009, 09:06 AM
thanks for the explaination
Old 01-25-2009, 09:14 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
This is an EXCELLENT explanation! Well done sparkness!
CR.
Charge Pump cadmonkey LinuxCNC (formerly EMC2) 8 04-06-2010 01:19 AM
Newbie- Charge pump setup zeta LinuxCNC (formerly EMC2) 6 02-23-2008 03:05 PM
Charge Pump ??? jack55 General Electronics Discussion 6 04-21-2007 02:59 PM
Diy Charge Pump Circuit? zigmart General Electronics Discussion 6 03-18-2007 07:28 PM
Charge pump mlaws1172 Screen Layouts, Post Processors & Misc 0 01-03-2006 10:46 PM
