Old 01-23-2009, 05:15 PM
djmrozin is on a distinguished road
My new V-Groove Router design
I have attached a edrawing of the new V-groove design I have been working on. Comments would be appreciated.
Combination of 8020 extrusions, hardwood and aluminum.
Cutting table is 36 deep by 31.75 wide by 6 high
Look forward to comments.
Dave
Old 01-24-2009, 07:45 AM
Here are a couple of jpg files if you don't have edrawing viewer.
Dave
ID:	74348   Click image for larger version
Old 01-24-2009, 04:07 PM
FandZ's Avatar
FandZ is on a distinguished road
Dave
Looking at that file in solid works almost makes me want to start using SW again.
A few questions. How do you plan to attach the angle without rollers rolling over the bolts? ANd the other,why didn't you just wrap it in 80/20 all around instead of using wood as hybrid?
Old 01-24-2009, 05:09 PM
Hello,
No bolts. I am going to weld the small angle that the bearing are going to roll on to the mounting angle iron.
Just used the wood to give it some "character" Don't know if it is good idea or not.
Thanks for the feedback.
Dave
Old 01-24-2009, 05:19 PM
FandZ's Avatar
Welding will work. Only other thing I worry about is on your y axis. Since you have it mount on an angle, you may have problems with racking because the gantry probably will bend those angles up and down. You may do better mounting the angle rail on a flat strip of steel and then mount the strip of steel with the rail on top of the 80/20.
Basically you'll just be inverting your design but gaining a huge amount of strength.
One last Q, how to you plan to adjust your rollers?
Old 01-25-2009, 07:41 AM
For adjustment, I will just oversize the mounting holes on one side of each pair of tracks, squeeze together and tighten. Simple but it should work.
Hlep me understand what your concern is with the Y axis. Not sure I under stand. I thought that mounting to the base angle iron of each track should add quite a bit of rigidity.
I appreciate the feedback.
Dave
Old 01-25-2009, 10:45 AM
FandZ's Avatar
Dave
Here is a quick picture of my concern. Maybe later I can sketchup a solution. But we are about to have breakfast at my house
Name:	gantry flex.jpg‎
My New 24x24 V-Groove Router Design Log widgitmaster CNC Wood Router Project Log 674 11-04-2010 02:26 PM
O-ring groove design - comments please octathorpe General Metalwork Discussion 8 06-23-2008 06:23 PM
101 Router Design diamus Open Source CNC Machine Designs 11 05-10-2008 05:09 PM
My CNC Router Design CNC_Brent DIY-CNC Router Table Machines 1 02-19-2008 04:38 PM
New Router Design bryanrabb DIY-CNC Router Table Machines 24 09-25-2006 05:15 PM
