Old 01-21-2009, 04:28 AM
micsit1 is on a distinguished road
All Aluminum Router- so far so good
First router built from parts collected at the junk yard.
Spindle borrowed from my Sherline mill.
Tried running 2 axis Z and Y, one at a time -good results- Rapids on Y much higher than expected
Yet still more work to do.
Thanks guys for educating me for the last 12 months
Michel
Name:	My router 0001.jpg‎
ID:	74158   Click image for larger version
Name:	My router 0002.jpg‎
ID:	74159   Click image for larger version
Name:	My router 0003.jpg‎
ID:	74160   Click image for larger version
Name:	My router 0004.jpg‎
Name:	My router 0005.jpg‎
ID:	74162   Click image for larger version
Name:	My router 0006.jpg‎
Old 01-21-2009, 12:30 PM
bkboggy is on a distinguished road
Very interesting design. Is the y-axis just resting on the table while x-axis is laying down on the table on its own? Or is it all connected? I just don't see where the y-axis and x-axis connect on those pictures.
Old 01-23-2009, 04:20 AM
Router Frame Base
BKBOOGY
No it's more conservative
This is what I'm doing today
The base is 16mm aluminum 800X460mm
The gantry upright 16mm aluminum 160X460mm
The piece which links them together is 80mm steel U channel with 6mm bolts
Michel
Name:	My router 0008.jpg‎
ID:	74296   Click image for larger version
Name:	My router 0009.jpg‎
ID:	74297   Click image for larger version
Name:	My router 0010.jpg‎
Old 01-24-2009, 04:27 PM
FandZ's Avatar
FandZ is on a distinguished road
Looks very professional, simple, and strong. You obviously have some great fabricating skills. I don't know if I would have covered up all the beautiful aluminum in black though. But that's personal taste.
Can you share some info on your spindle. I'm going to start off with a router but eventually I'd like to work my way into a spindle.
Old 01-25-2009, 05:47 PM
As I said before I "borrowed" the spindle from my sherline 5400 mill so I can return it to the mill when I am finished using it on the router.
the motor is activated (ON/OFF) by Gcode M3/M5 through a 120/240V optorelay connected to my BOB pin #16
Details from www.sherline.com
P/N 33070 Headstock, DC motor and speed control assembly with 10,000 RPM pulley set installed
Weight 10 lbs $380.00
Name:	Sherline Headstock.jpg‎
Old 01-26-2009, 11:23 PM
I am new, so I'm curious... why use that instead of a router?
Old 01-26-2009, 11:28 PM
FandZ's Avatar
All I know is they are quite and if ou have the right controller the power can be increased to stay at a certain RPM under load. Hopefully micsit1 can enlighten us some
Old 01-27-2009, 08:24 AM
"Originally Posted by bkboggy
All I know is they are quite and if ou have the right controller the power can be increased to stay at a certain RPM under load. Hopefully micsit1 can enlighten us some "
First of all I save money using the same item for both machines.
Second Routers are designed for wodworking and have a lowest speed (around 10000 rpm), too high for cutting metals.
Third as Frandz said the controller has variable speed from 0 to 10,000 rpm and compensates the drop in speed when under load
Old 01-27-2009, 02:36 PM
True.... my Hitachi router is 8,000-24,000 RPM....
Old 02-12-2009, 03:11 AM
Testing my Router
Build Thread- Kress Router...any good! flyboypete DIY-CNC Router Table Machines 8 10-12-2010 06:58 PM
Just can't get any sort of good finish boring aluminum on lathe - tips? SRT Mike General Metalwork Discussion 22 06-30-2008 11:42 AM
Face Mills? Which one to choose for a good finish on aluminum? peter.blais General Metal Working Machines 20 08-25-2006 10:41 AM
Using a CNC Router on Aluminum emarthinsen DIY-CNC Router Table Machines 2 02-20-2006 06:47 PM
Is a router only good for routing? zealouse Commercial CNC Wood Routers 2 07-30-2005 10:17 AM
