Old 01-16-2009, 03:30 PM
technosteve is on a distinguished road
Disable feature on Geckodrives
Does anyone use the 'disable' feature as an E-Stop? Sounds like it makes sense to me, any ideas?
Is this feature typically reserved for something else?
I'm just using a basic optoisolated breakout board.
Old 01-16-2009, 03:47 PM
samco is on a distinguished road
It is my opinion that the E-Stop should kill the power to the drive. Not just disable it.
sam
Old 01-16-2009, 04:54 PM
Bubba's Avatar
Bubba is on a distinguished road
I use it in conjunction with the rest of the process of cutting power. I also use it when one drive faults for whatever reason to kill the whole process.
Two methods are better than one.
Art
Old 01-16-2009, 05:13 PM
Santa Fe Al's Avatar
Santa Fe Al is on a distinguished road
Bubba,
Like you, I have my G251's wired to the E-Stop plus a SPST switch hooked in series to disable any one, or more, drive(s). In this way, I can test an axis, etc, without moving all of the stepper motors while tuning or adjusting the stepper motor that I need to work on.
Al
Old 01-17-2009, 10:00 PM
johnmac's Avatar
johnmac is on a distinguished road
If I am wrong about this, someone please correct me. If you use the disable feature, it kills the power to the motor(s). If the machine is in motion, it will coast to a stop. If the E-stop switch is wired to a pin that is assigned as E-stop in Mach, step and direction pulses will stop being sent and the hold current applied to the motor(s) will act as a brake to stop the motion.
John
What Servo Motors to Buy to be Controlled by Geckodrives? waleed alhadidi Gecko Drives 0 09-16-2008 11:39 PM
Need Help!- How to disable ac97sound? Mr Bits LinuxCNC (formerly EMC2) 4 05-01-2008 05:25 PM
Disable switches swarfmacdaddy Gecko Drives 9 10-24-2007 02:28 AM
Disable with Mach belli Mach Plasma / Laser 3 07-14-2007 03:53 PM
Gecko 201 disable? LEWENZ Gecko Drives 6 01-12-2007 09:24 PM
