Old 01-12-2009, 04:14 PM
lkasdorf is on a distinguished road
Need driver sugg. for my steppers (Pac Sci)
I picked up a Dahlgren 24"x16" engraver, that I'm going to use as a basis for a CNC router.
These machines are 2.5 axis- the Z is an air solenoid that is either up or down. So, I'll want to install a real Z axis and stepper. I could use the existing motor, or use a trim router.
The electronics package that came with it seems to be useless (doesn't seem to be able to cause any movement at all).
I want to run something like Mach on a cheap computer, and get a suitable driver board that I control from the parallel port or USB
So, I want a suggestion for a suitable driver board. I can make the power supply out of stuff I have around mostly.
My steppers say:
Pacific Scientific
Powermax 1.8degree step motors
P22NRXB-LNN-NS-00
3.52 VDC unipolar
3.3 ADC unipolar
date: 95493041
40 degree centigrade operation
Money IS an issue, and I am a very experienced elec tech, so assembly/soldering is no problem.
Old 01-12-2009, 04:29 PM
jalessi's Avatar
jalessi is on a distinguished road
Smile
lkasdorf,
This is a very inexpensive solution.
http://www.hobbycnc.com/products/hob...er-board-kits/
It has 3 amp output which is close enough to the rated capacity of your motors.
A heat sink is required however it is not included in the kit.
Have fun.
Jeff...
Help with Steppers and Driver sloop Stepper Motors and Drives 5 01-30-2007 05:35 AM
Test steppers with driver only? monte55 Xylotex 0 10-19-2006 06:55 PM
How much does a driver board affect smoothness of steppers? phantomcow2 Stepper Motors and Drives 1 11-07-2005 02:44 AM
