01-13-2009, 01:21 AM
Okay, Let me first apologize for my previous post in which I did not describe my project or concept in detail…I was falling asleep ay the keyboard! Lol. I have thought about my design more, and have come up with some more details I’d like to get suggestions or opinions about.
I have spent a lot of time sifting through other peoples designs to see what options are available to me based upon what tools I have and my skills or lack there of to use them to any degree of satisfaction. That’s why I am excited to build a CNC Router to help aid me with my quest to build things with some quality and precision with a hint of professionalism. As I read through the trails and errors of others, my understanding and the complexity of my design gets more difficult.
I’m fascinated by the 8020 concept because of its wide variety of uses and its ability to allow the CNC parts and tools to be interchangeable and upgradeable, so I would like to use this as my frame and whatnot. The big downfall I see with using 8020 is the price, but in the end I know it will be worth it. Id like the cutting bed dimensions to be around 5 feet long x 3 feet wide x 1 foot height. This way I’m not limited by to small a machine for some of my future projects/upgrades.
Since my hobby ranges from mostly electronics to stupid little gadgets, I want a machine that can cut out holes and shapes in thin metal/plastic/wood as well as drill holes and etch PCBs, so I will need a powerful router that can be gentle with certain materials.
But to the feature Id like to add the most would be some sort of printer head, that once I cut out some metal say for a controller or panel, after I wipe it down and clean the surface, I can then go back over it and print switch labels or signs, Ect. Ect. This I haven’t started to research yet, I figured I would ask for opinions or suggestion to if this is possible, and how hard it’s going to be to get it to be a clean print. Maybe mount it on the gantry under the routers Y-axis linear support beam with its own z axis bearings to bring it up to the top when it’s not used, and lower it down to the surface when I want it to print on. This way it’s on the same gantry, and I can put a cover over the heads to prevent dust build up.
I’m open to any suggestion you might have and I appreciate you taking your time to read and assist. Meanwhile, I have a lot of questions that I need answers to, so I will start combing through threads once again. Happy CNCing! |
