Old 01-11-2009, 08:49 PM
BWay is on a distinguished road
Stepper or Servo? Best choice and best source...
I am currently working on my first CNC router. I am planning a 4 axis machine and will be using Nema 23 size motors. A friend strongly recommended servo motors but am wondering if the extra cost is justified? What will gain by using servo's? Also, I have noticed that whether I use steppers or servo's there is many sources and the prices vary greatly. What is a good source that provides good quality at a good price?
Thanks!
Old 01-11-2009, 09:27 PM
YZF YZF is offline
YZF is on a distinguished road
Stepper vs. servo
Very generally for a similarly sized motor you can run at higher speeds, higher torque and with a higher "stiffness" with a servo motor.
The "price" is somewhat higher complexity and the need to tune the control loop for optimal performance which can be tricky. Traditionally servo systems are more expensive due to the cost of the control electronics, the encoder and the software but this may be changing.
If a stepper motor will meet your requirements and is cheaper it is much simpler to use in a home CNC application.
By the way, it is also possible to run a stepper motor as a servo motor and a 3 phase brushless motor usually used as a servo motor can be stepped in open loop...
Hope this helps...
Thanks!
choice of diy servo driver package GMS Open Source Controller Boards 2 10-03-2007 09:27 PM
Stepper Drivers/Electronics choice - advice please! keen Gecko Drives 5 06-14-2007 09:48 AM
stepper motor -b.o.b choice jarr88 Gecko Drives 0 09-28-2006 06:43 PM
Wich Stepper Motor you will choice? samsagaz DIY-CNC Router Table Machines 9 11-09-2005 04:38 PM
Stepper choice JW Peters Stepper Motors and Drives 0 05-26-2005 09:09 PM
