Old 01-10-2009, 01:24 PM
tahustvedt is on a distinguished road
How fast is your router?
I've gradually optimized my router over the last year and half since I built it. I have been running with a rapid speed of 6000 mm/minute velocity and 1500 acceleration for a while now with occasionally losing steps in Y because of a tight backlash ballscrew, thinking that's pretty fast. I even milled aluminium at that speed. Today I tried increasing the voltage from 24 V to 28 V. Now it rapids at 9000 mm/minute (150 mm/s or 354 IPM) velocity with an acceleration of 1700 without ever losing steps where it would lose steps before. I haven't tested a lot of milling yet though, but it was I tried running at 10000 mm/minute (167 mm/s or 393 IPM) with an acceleration of 2000 while planing the table with a 10 mm endmill and that went fine as well, but I turned it down a little to have headroom.
I should say that I have pretty small steppers (1 Nm on Y and 1,23 Nm on X), and ball screws on X and Y. I tried replacing the Y with a larger, stronger Sanyo Denki 1.63 Nm stepper but it only made it lose steps even at lower speeds. I'll save that motor for a higher voltage day.
How fast is fast, exactly? How fast is your router?
Old 01-10-2009, 02:37 PM
Khalid's Avatar
Khalid is on a distinguished road
My first router run at 150IPM Jog and cutting with 100IPM. (Area 3ft x 4ft)
My second Router run with 100IPM Jog and i cut at 80IPM. (Area :" " ")
My 3rd router all steel 4.5'x 5' run at 750IPM Jog and start cutting at 500IPM..
Old 01-10-2009, 03:18 PM
750 IPM jog. That's pretty fast.
Old 02-06-2009, 03:16 PM
1041448 is on a distinguished road
Hi all.
I'm building a CNC wood router machine , but i'm a little stuck with the mechanical things . I am trying to get the acme threaded lead screw and the stepper motors , but i dont know the specifications, which should i get first?? how to choose it's specification???
what should the speed of motion on each axis Be??
My machine is a 3 axis wood router , i'll be drilling MDF wood.
Y-axis : 4 feet long ,25 lbs horizantal movement
X-axis : 2.3 feet ,14 lbs horizantal
Z-axis : .6 feet ,11 lbs vertical
Help please ,thanks.
How fast is this? jmytyk DIY-CNC Router Table Machines 8 02-07-2009 05:41 AM
Need to build a 4'x8' CNC router fast! robertmonroe Joes CNC Model 2006 9 11-27-2008 09:10 AM
Need help Fast on 540 gunlocators Gecko Drives 14 10-07-2008 10:30 AM
Scary fast G203 cnc router/plasma cutter Dan Mauch DIY-CNC Router Table Machines 11 06-09-2007 11:52 PM
Do you have a fast DSL? Help! ESjaavik CNCzone Club House 11 08-18-2004 09:25 AM
