Old 11-24-2004, 04:58 PM
MrBean's Avatar
Gold Member
MrBean is on a distinguished road
My router caught fire today. Which new spindle?
My £25.00 router finally gave up today, and set itself on fire. I really only bought it as a tester. Now I know the CNC machine works ok, I need a new cutting spindle.
Anyone have any recommendations from expirience. I was thinking maybe along the lines of a Makita or Porta Cable perhaps even a bosch. Would need to be the fixed base type, so I can take the motor/spindle part out and fix it to the CNC.
My main priorities are: Durablility, Quietness. Variable speed would be nice too.
I'm based in the UK, but would buy from the US. I don't mind paying good money as long as I get a good router.
Recommendations please. Good or bad.
Many thanks.........
Old 11-24-2004, 06:08 PM
MrBean's Avatar
Gold Member
I've had a search on the web and can find only one fixed base router in the uk. A 900 Watt Makita.
Have found loads in the US, but appear to be 120 Volt AC. Does anyone know if these would run ok from a UK 240V to 110V site transformer?
Old 11-24-2004, 08:26 PM
HuFlungDung's Avatar
Moderator
By all means, 120 volts is 120 volts no matter where it comes from Just watch that the wattage of the tranformer is high enough for the load of the motor.
Old 11-24-2004, 10:07 PM
JRoque is on a distinguished road
http://www.internationaltool.com/220volt/220router.htm
Cheers,
Julio
Old 11-25-2004, 07:36 AM
kong is on a distinguished road
i bought my makita from www.coastaltool.com and the service was exceptional. Delivered within 3 days! just bear in mind the VAT you will have to pay for importing it.
Yes, it will run fine from a regular bulding site transformer, but to add to Hu's comments, check the duty-cycle of the tranny. Mine is rated for 15 mins on 15 mins off at peak wattage (3kw), but since I am only using about half that, I have had no problems with it cutting out........yet! They are sealed units, so perhaps one day I should add a fan?!
Old 11-25-2004, 07:27 PM
yukonho is on a distinguished road
Just switched to a porter cable trim router. Quieter and much more solid than anything else I have tried. Can only use 1/4" shank bits though
My machine is small, not sure what size you need. I have had two other spindles with variable speed, and have never run them at anything but max RPM.
co
Old 11-26-2004, 05:02 PM
MrBean's Avatar
Gold Member
I've ordered the Makita router from Coastaltool.com as recommended by Kong. Many thanks for that.
Why is it that I can find only one router in the UK that the motor/spindle assembly can be withdrawn from, and that's after hours of searching. There are almost no fixed base routers available here at all.
The one I did find is a Makita, but it is less powerful and more expensive than the one I've ordered from the US, that's including the $80.00 shipping and UK taxes.
Now I have to order another one of those cheapo routers that catch fire in under 20 hours of use, so I can machine a bracket to mount the new Makita.
Next up. Improved stepper drivers.........
This CNC hobby is really starting to soak up the money now!!!! Good news is I may have found a paying customer.
Thanks to all for the router info's.......
Terry
Sherline spindle to 30k RPM -- am I crazy? nicad General Metal Working Machines 21 11-17-2010 02:57 PM
CNC Controlled Spindle motor speed control gregmary General Electronics Discussion 13 02-27-2009 07:01 PM
Finding The Right Router Crushmonkey Commercial CNC Wood Routers 22 06-19-2006 01:17 AM
Wood router, suitable spindle drive like shopbot? GalaticDan Commercial CNC Wood Routers 5 06-09-2005 11:32 AM
UK router spindle? kong DIY-CNC Router Table Machines 14 08-25-2003 09:27 AM
