Old 12-30-2008, 01:04 PM
SPEEDRE is on a distinguished road
Table Top Set Up
Not sure if this is the right place for this thread but here goes. For a table top gantry, with 14" x 25" machine envelope. I've built several enclosures for it and they are just butt ugly and unwieldy. Take up a lot of what is wasted space. What if I set it at an angle, front to back of about 30 deg. set a trough at the bottom for chips. I am thinking this will reduce space needed for it. But, what could be the issues with moving the " Y " axis as it either pushes or pulls the " Z' carriage along, or should I even be concerned? Has anybody ever done something like this ?. Comments please
Old 01-02-2009, 08:54 AM
Bump. This must be a boring subject, or one thats been talked out to death. It's OK I understand.
Old 01-02-2009, 09:14 AM
jsheerin's Avatar
jsheerin is on a distinguished road
You can calculate how the loads will change. It will take more force to move the gantry up the table because you will be effectively lifting it. How much force and whether or not it's a significant amount compared to the cutting forces you are moving against now depends on your design. If your gantry is light and your drive system generates lots of force, no big deal. If your gantry is heavy and your drive system is just barely adequate to cut your parts when horizontal, you will likely have problems or at least need to reduce your cutting speeds and acceleration.
Also, if your linear bearings don't support your gantry very well, that could also cause problems. It's really all in the implementation.
Old 01-04-2009, 09:30 AM
Thanks. My gantry is light, all alum. with 247 oz HD steppers. I plan to cut mostly wood and plastic sheet max. in wood 1.00" and plastics max .375" . I would just like to limit the space needed to enjoy my machine. What do you think will the , can the machine take it????
another 4 x 4 table Steve-M Plasma, EDM and other similar machine Project Log 47 06-24-2009 03:17 AM
DYNA CNC TABLE WITH WATER TABLE DISCONNECTED CNC Plasma and Waterjet Machines 0 06-06-2008 08:04 PM
open table vs closed-table gantry setups nicanor76 DIY-CNC Router Table Machines 2 04-21-2008 12:35 PM
XY table design basics, linear ways to table size ratio? Konstantin Mechanical Calculations/Engineering Design 0 03-13-2007 12:21 PM
Off goes the table! zoeper Bridgeport and Hardinge Mills 4 07-13-2006 07:35 AM
