Old 12-29-2008, 08:24 PM
ballbearing is on a distinguished road
Question Basic Power Question
Hi Folks:
I am looking to power 3 Heavy Duty Brush type Servo motors that have a spec. of 60VDC @46Amps Max and 48VDC@20Amps operating. I have the opportunity to buy a power supply that puts out 48VDC @50Amps. My question is will this PSU toast my motors ? Is there a way of using this PSU and limiting the current somehow ??
Ballbearing
Old 12-29-2008, 09:44 PM
Al_The_Man's Avatar
The power supply only supplies the current demanded of it, IOW it is better to be high on the current rating than on the low side.
Also your drives normally should have the capability of Current limit which also protects the motors.
Old 12-29-2008, 10:22 PM
Thumbs up
Al:
Thanks a bunch for your guidance on this....I had a feeling about the current consumption characteristics....just couldn't remember the Grade 11 Physics? The PSU that I am looking at buying, is actually 2 - 24VDC@25Amps and I was considering connecting them in Series to make up the 48@50Amps...is this Kosher? Also, when considering Brushed Servo motors, does it matter if the PSU's are Regulated or Unregulated ??
Thanks Again Al
Cheers
Ballbearing
Old 12-29-2008, 11:20 PM
Al_The_Man's Avatar
Series will only increase the voltage to 48V the current capacity will remain the same (25a).
Parallel, the voltage remains at 24v, the current capacity will double.
It is not necessary to have regulated power supplies for servo applications.
Old 12-29-2008, 11:57 PM
Thumbs up
Al:
Thanks Again. I guess I will keep looking for a PSU. I'm on a more refined track now :-)
Cheers
Ballbearing
a very basic fan question. cyclestart General Electronics Discussion 2 07-06-2008 06:43 PM
Very Basic Question H2ODiver General CAM Discussion 4 07-27-2007 08:51 AM
i want basic design of power skrew elmo7andes CNC Wood Router Project Log 0 03-05-2007 02:11 PM
Basic power supply question Greolt General Electronics Discussion 15 06-07-2006 06:13 AM
REALLY basic Question Dongle Mechanical Calculations/Engineering Design 25 03-14-2006 03:47 PM
