Old 12-23-2008, 01:04 PM
Coatsie is on a distinguished road
(HELP) Building a cnc router (HELP)
Hi, People
I am looking into build a cnc router/ plasma cutter, I really don't know where to start, I would like it to be made out of steel for rigidity, i currently work in a machine manufacturing workshop so i have a lot of machines available at my disposal, plus plenty of kit, welders, shot blasting, grinders, mills, lathes, etc etc.
I am looking at having the bed of the router a meter square, any ideas on how to approach this idea? designs, drawings, electronics, material sizes etc etc.
Is there any drawings or designs people have used that I can follow? This would be very advantageous.
Many thanks.
CoatSie.
Old 12-28-2008, 02:09 PM
lsalme is on a distinguished road
DIY router info my 2 cents
I looked around quite a bit and found that at present v-bearings on mild steel are being used with great success on the latest DIY routers. User dertsap has many threads here on the zone and youtube videos of a robust and i believe welded steel gantry using v-bearings on steel angle and steel tubing. I am currently building a Joes 4x4 router which also uses v bearings on steel angle iron. Joes design uses MDF and structural aluminum extrusions. If i had access to a full metal shop i would probably build something more like dertsap's. Another build i liked when i was researching builds was from a builder Spalm with links here on the zone and off on another woodworkers forum. Spalm's build is wood and evolved to use angle iron, it is a nicely photographed reference of the basic mechanics.
http://lumberjocks.com/jocks/SPalm/blog/2248
Build Thread- Building a CNC Router; by someone who can't build a CNC Router Womble DIY-CNC Router Table Machines 2 09-27-2008 07:51 AM
Building 1st router. skipper_52 DIY-CNC Router Table Machines 2 03-06-2008 05:44 PM
building a cnc router TheCrazzyman Mechanical Calculations/Engineering Design 3 10-06-2006 12:05 PM
5' x 10' router building need help stevelang DIY-CNC Router Table Machines 13 08-29-2005 12:55 PM
Building my second cnc router balsaman CNC Wood Router Project Log 267 10-11-2004 02:15 PM
