Old 12-18-2008, 07:25 AM
carsonau is on a distinguished road
Widgitmaster / similar CNC kit required - PCB
I was planning to get a widgitmaster midi, but they are all sold out now - how long for the next batch (if a next batch exists?).
Are there any other CNC kits (i already have NEMA 23 motors) that are similar to the widgitmaster midi?
I am planning to mill PCB's with SMD footprints.
Also, what router should I be using for PCB's. Will a ProXXon suffice?
Thanks for your help in advance
G320/G340 'Required Direction Setup' and 'Required Direction Hold' times? margni74 Gecko Drives 2 12-05-2008 08:10 PM
Widgitmaster mini henrikw DIY-CNC Router Table Machines 20 09-19-2008 08:13 AM
Newbie- Any info about WidgitMaster? efimius Want To Buy...Need help! 8 08-07-2008 10:16 AM
How do you do it? Any ideas, the WidgitMaster needs help! widgitmaster Mechanical Calculations/Engineering Design 13 04-26-2006 04:30 PM
