Old 12-10-2008, 09:40 PM
bkboggy is on a distinguished road
What kind of router (spindle)?
So I'm looking for a router with a fixed removable base and maybe (don't really need it all that much) a plunge base (doesn't have to be a kit if bases could be added on later). I'll need the fixed base to cut and drill the parts for my future cnc and the plunge base might come in handy to drill (but no real necessity for it since I can probably get away with an electric hand drill), and then I'll be able to use the router as the spindle.
My budget is $200.... $250 tops.
It doesn't have to be a kit, but that would be the preference, unless someone has a better idea or thinks I should buy them separately. If I can buy them all separately and maintain $250 budget that would be just as good. I'm all ears )
I'll use it for wood, plastic, foam and thin aluminum on buildyourcnc.com CNC that I'll build from the instructions on the website. How big should the router be? What voltage, rpms and hp am I looking for? Things like that... I know next to nothing about routers. Do I need a big router to perform those tasks or should I go with something like RotoZip?
Anyone has any recommendations? I'm open for any and all ideas.
-BK
Old 12-10-2008, 11:25 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
Ive got a craftsman plunge router with the removable base on mine $129 CND
it works pretty good , it will handle a 1/2" endmill and light cuts on aluminum , when i push it to a few hundred ipm it doesnt take to long to machine a part out ,
others may recommend higher quality routers but for my use the craftsman has proven its worth , and when i do kill it ,then it wont hurt my wallet to replace it
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 12-11-2008, 12:38 AM
What do you think of these?
HITACHI KM12VC 2.25 HP FIXED/PLUNGE BASE ROUTER KIT
Porter-Cable 892 2-1/4 Peak HP Router Kit
Porter Cable 893PK 2-1/4 HP Router Kit
DeWalt DW618B3E VS 3 Base Router Kit
Old 12-11-2008, 12:42 AM
dertsap's Avatar
Gold Member
they make good routers from what i understand , but i've got zero experience with them
Old 12-11-2008, 01:21 AM
Everyone says that Hitachi makes the quiet ones, Porter Cable seems to be the most expensive, DeWalt.... I see that in all stores. Not sure which one to go for....
Old 12-11-2008, 07:02 AM
blackbeard52 is on a distinguished road
bkboggy
here is a hitachi 2.25 hp for $120 http://www.tools-plus.com/hitachi-m1..._term=HTCM12VC
Old 12-11-2008, 08:11 AM
I found this kit, just for a bit more:
http://www.amazon.com/exec/obidos/tg...UQBAP&v=glance
Same version router.
Old 12-11-2008, 08:13 AM
It won't be too big or heavy for my cnc, right? Will it also do okay with foam? It is variable speed after all.
Old 12-11-2008, 08:26 AM
groov is on a distinguished road
go for it!!!
I have a Hitachi on my system....never looked back. I also purchased the router with the base just in case I wanted to do manual work with it. The price is right and you won't regret it.
groov
Old 12-11-2008, 10:07 AM
Everyone seems to praise how quiet Hitachi routers are, is that true? Also, between Hitachi, Porter Cable and DeWalt.... Hitachi is the best choise? I just don't want to have to buy another router for a while.
Should I get one of the part replacement plans form amazon? There's 2 ($24.99) and 1 ($14.99) year plan.
http://www.amazon.com/2-Year-Replace...l_sp_SVC_1_img
http://www.amazon.com/1-Year-Replace...l_sp_SVC_2_img
Or should the limited 5 year warranty on the item itself be just fine?
  #11   Ban this user!
Old 12-11-2008, 08:16 PM
Should I go with a lower HP router or higher HP router for the materials I will work with? (lots of wood, some plastic, lots of foam and some metal)
The one that everyone seems to like around here is
http://www.amazon.com/Porter-Cable-6...R5WTE5XWNB9W7K
or should I go with that Hitachi one?
  #12   Ban this user!
Old 12-12-2008, 12:30 AM
Well, not getting anymore answers from anyone, so I'll just go ahead and go with that Hitachi kit. There's only 4 left and it's at good price.
Tags
cnc, cutting, drilling, router, spindle
router vs a spindle woodman08 WoodWorking 3 01-15-2008 03:55 PM
cnc router spindle .xXACEXx. DIY-CNC Router Table Machines 3 06-29-2007 09:14 PM
What kind of router bit? lgroulx200 DIY-CNC Router Table Machines 2 12-31-2006 07:28 AM
What kind of Spindle with resonable price for my Mill CNC ? Help.. Calico General Metal Working Machines 0 06-27-2005 09:15 AM
Spindle motor-what kind 2muchstuff DIY-CNC Router Table Machines 2 05-19-2005 08:16 AM
