Old 12-10-2008, 06:42 AM
voltsandbolts's Avatar
voltsandbolts is on a distinguished road
Material thickness chart?
I am trying to design my first router and need accurate thickness information.
Is there a chart that lists the actual thickness of various materials that are commonly used in Home build CNC machines?
MDF:
¼”=
½”=
¾”=
Plywood:
1/8”=
¼”=
1/2”=
¾”=
Plastics: …
I guess you get the point, has this info been assembled someplace already?
Thanks.
RobWms
Deeds not words...
VoltsAndBolts Alternative Power Forums http://www.voltsandboltsonline.com/
Old 12-10-2008, 08:07 AM
ger21's Avatar
MDF is usually what it's supposed to be, maybe just a hair thicker (.005±) , but not enough to worry about.
Plywood, on the other hand, can be all over the place. Some is actually what it's supposed to be. Some is 1/32 smaller. And some is metric, so 3/4" may be 18mm. you really need to know exactly what you'll be using with plywood.
Old 12-15-2008, 10:42 AM
Thanks for the info ger21.
Deeds not words...
Need Help!- Working with stock thickness material. svatchi Work Fixtures and Hold-Down Solutions 1 03-29-2008 08:36 AM
comparator chart jas6142 Calibration & Measurement 0 02-06-2008 04:13 PM
chart on threads DONNYBRASS General Metalwork Discussion 7 12-12-2007 05:47 PM
Mirror thickness CNCadmin Laser Engraving & Cutting Machines 8 08-04-2005 02:32 PM
