ok i am wanting to build a cnc router for cutting mdf and light aluminum. my question is if i build a smaller machine out of mdf (12"x28" cutting size) out of mdf. will it be able to cut 3/4 aluminum if i do 1/32 passes? the only reason for the small mdf machine is to make the actual machine. also my gantry consist of .75 inch main supports on each side and my gantry beam is a 4x6 inch 1/4 inch wall beam. cutting table size will be 6'x10'. if i use a good quality spindle and cutter i should be able to cut steel correct? |
could be done if you use steel channel , linear rails and bearing blocks , ball screws and a quality high torque low speed spindle
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| I'm not an expert and this is just my opinion ![]() 1/32" of an inch cuts in aluminum sounds too heavy. I think steel is out of the question. In theory lighter and lighter cuts and smaller tools can reduce the cutting forces but in practice there's only so far you can go before your tool will just bounce of the surface you're cutting. Even if you can cut the finish and tool life will suffer. The accuracy will also be questionable. A lot depends on the exact construction, the rails etc. Metal working machine are usually massive pieces of steel (steel is about x100 stiffer than MDF). With very careful construction you may be able to cut aluminum using very light cuts, I think steel is not possible, never built an MDF machine myself though... |
heres how my build process is going. i will build the mdf machine with the same servos and controls i will be useing on my main machine to save cost. the only reason for the mdf machine is to cut out a few pieces of 3/4 aluminum for the main machine. once those are done the mini mdf one is getting trashed. once my main machine is finished (all the gantry and axis parts are 3/4 aluminum. the frame to support the machine is 1.5 square tubing (maybe 80/20) i have a 3.5hp water cooled spindle i will be using on my machine. and will frequently machine mdf and sometimes aluminum. i am just curious if i can cut steel with a 3.5hp spindle (1/4 inch plate i dont have access to a water jet and i need to cut some pieces out for a custom bumper. all linear motion will be rack and pinion most likely belt driven |
I think your plan is good assuming the accuracy you want in your aluminum cuts is not too demanding and that you are careful to get your mini machine as rigid as you can... Good luck. |
| If you are considering building out of aluminum extrusion, why not build the whole thing out of it? What parts do you need to cut? Ahren www.cncrouterparts.com |
| Dumb Question | Pretorien | Benchtop Machines | 5 | 10-11-2007 11:15 AM |
| Really dumb question | ios1000 | Fanuc | 5 | 07-31-2007 12:38 PM |
| One Dumb Question | Biggermens | General Metalwork Discussion | 14 | 04-11-2007 03:49 AM |
| Dumb Question | elogicca | Mach Mill | 4 | 06-11-2006 03:28 PM |
| dumb question | rob1215 | General Metal Working Machines | 4 | 06-24-2004 12:27 PM |
