Old 11-12-2004, 03:31 PM
WoodSnarfer's Avatar
Gold Member
WoodSnarfer is on a distinguished road
Two servos - one driver
If I wanted to run two servos from a single driver, would that be okay? If so, how do you implement? Is it as simple as hooking all the power and encoder wires up in parallel?
The goal would be to move a gantry with two parallel ball screws, driven by two identical (smaller) servos - having both servos stay in synch.
Silly newbie question, or is this possible?
Thanks,
Chris
Old 11-12-2004, 03:45 PM
braidmeister's Avatar
braidmeister is an unknown quantity at this point
Chris,
I don't believe that you can do that for a number of reasons. First of all, it is very possible that one encoder will fault before the other due to over driving the motor, dirt in the encoder and other causes. If run that way, BOTH motors would fault. All of the servo drives that I know of only interface with one encoder. There are not provisions for 2.
You will also have issues with power to the motor because you will be pushing 2X the Amps compared to only that of 1 motor...
The way to do would be to run 2 servos & 2 drivers for the X and then set it up in Mach2 to reverse the direction of the 2nd motor so that it spins backwards in relation to the 1st X motor.
-Brady
Old 11-12-2004, 04:43 PM
*Registered*
ESjaavik is on a distinguished road
@woodsnarfer: The most silly questions are the ones you don't ask. Because they don't make you smarter.
No you can't do that because a servo motor feeds it's error back to the drive, that will then take corrective action. When you have 2 servos, they have different errors, and one drive cannot correct those as it will require different action.
One solution is to use one motor driving both screws. The difference in error between them will be negligible if you make the coupling between them stiff and with as little backlash as you can.
Old 11-12-2004, 05:58 PM
Chagrin is on a distinguished road
If the shafts of the two motors were linked and only one encoder was used, this would work (to an extent), wouldn't it? Perhaps a timing belt synchronizing the two motors in this instance.
Obviously not an ideal, but just a curiosity.
Old 11-12-2004, 07:06 PM
Gold Member
Thanks...yes, I now see that a better solution is to use one large servo, and tie the two separate ball screws together via common belt. With two servos running in parallel, I can also picture one motor failing, and the other one causing the gantry to rack (or worse).
Thanks!
-Chris
Old 11-12-2004, 07:34 PM
ger21's Avatar
Something like this.
http://website.lineone.net/~rmtucker/
3rd picture in the second row
Old 11-12-2004, 07:46 PM
Graham S is on a distinguished road
This is what I am trying to do (two screws, one motor and belts) so it had better work
Old 11-12-2004, 08:48 PM
Gold Member
Ahh, yes...that would be the ticket
Anyone know a source for the drive sprockets and idler bearings? I'm assuming that the motor mount was a custom-fabricated part...wonder if it has integrated tension adjustment (?)
Thanks,
Chris
Old 11-13-2004, 04:46 AM
The motor/mount can slide up and down for tension adjustment I think.
You can get timing belts and pulleys from:
http://www.sdp-si.com/
They also have a lot of info on the site.
Servos pausing and starting InsaneEPP Servo Drives 9 03-15-2005 08:45 PM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 05:05 PM
Replacement servos, not sure what I need.. yukonho Servo Motors and Drives 4 01-03-2005 04:56 PM
Fun with floppy stepper and driver Konstantin General Electronics Discussion 5 03-08-2004 01:18 AM
Have Servos Need Driver... Help! elalto General Electronics Discussion 6 08-08-2003 07:39 AM
