I am trying to install a new controller board that I purchased off EBay and need some help. Here is a link to show what I exactly purchased; http://www.cncgeeker.com/index.php?m...&products_id=2 I am not 100% sure how to hook up the power supply. It shows it needs a 12v and a 7v power supply. I have not ran into this before and would appreciate some help. Is the 7v something I actually need and if so can I just get it from Radio Shack? Here is a picture of the board; ![]() Thanks
__________________ Please check out my CNC blog http://cncinside.com |
| I looked at your manual and the 7 volt supply is stated to be a voltage of 7 to 12 volts with a typical 9 volts. This is probably used to power the chips on your board and would require very little power. A simple 9 volt DC power block should be all you need. The 12 volts is the power to the motors and is rated at 5 to 36 volts at 1 to 6 amps. this depends on the power required by your motors. Hope this helps George |
the manual is a little ambiguous as to how much amperage required if it si per board or per system, it says connect ps to the 'controller.' It mentions 1A for the >7v (<12). It is unclear if 1A per board, but I would guess for all the boards combined the total supply for logic should be well under the 1A combined. If you have a 9V wall wort lying around with the 1A output, I would say give it a go, starting with just one axis, power down and add an axis, ... etc. If any board led's are fully lit and remain so as you add boards, than it is fairly safe to guess what they meant. The power supply to drive the motors is a different story and highly dependent on the motors you plan to use. But using the provided '2.5AMP@36VDC'per axis times number of axis used, you will have the maximum permitted and you will only have to limit the outputs for any motors below the 2.5 A rating. You can likely get away with much less than 18A PS if using all 6 axis, in that it would be quite unusual (or fascinating) to have all drives going 100% at the same time for any duration. |
| Build Thread- Building a CNC Router; by someone who can't build a CNC Router | Womble | DIY-CNC Router Table Machines | 2 | 09-27-2008 08:51 AM |
| Newbie- Does anyone own a EZ Router Machine? Plasma or Router. | sngatlanta | Commercial CNC Wood Routers | 30 | 04-11-2008 11:48 AM |
| Router Using 3/4" MDF (first router build) | eguy208 | CNC Wood Router Project Log | 33 | 04-11-2008 11:33 AM |
| Using a router for the 1st time. Need advice of cut speeds, router bits etc. | Apples | DIY-CNC Router Table Machines | 19 | 09-23-2006 04:33 PM |
| Surfcam PP for Isel router / Precix router | IvanTochev | Post Processor Files | 2 | 05-12-2004 01:27 PM |
