  #13   Ban this user!
Old 12-02-2008, 10:28 PM
tgrandahl is on a distinguished road
So even in mounting the screw, think about mountings that make it easier to mount and remove (like a bearing plate) that bolts to the outside of the beam flange with a hole big enough in the flange to pull the whole screw through.
Alan[/QUOTE]
Thanks that's a good point and this being my first machine i'm sure i will be doing plenty of experimenting with components.
I do need to work on the bearing blocks, probably next order of business. Until then, I cleaned it up a little bit.
Name:	frame view 5.jpg‎
ID:	70835   Click image for larger version
Name:	frame view 6.jpg‎
  #14   Ban this user!
Old 12-03-2008, 09:16 PM
lead screw bearing blocks
So i added in some lead screw bearing blocks, i modeled them from ones available from PRECISIONTECHMACHINING.COM. At this point i am not sure if i am going to make my own, I already have my work cut out for me.
Constraining them to the model brought up the question of tension however; if a lead screw is slightly shorter than the spacing between the bearings, wouldn't this create significant backlash?
So would it be a good idea to machine the lead screw slightly longer than needed and have one bearing block mounted with springs between the block and bolt heads?
Peer to Peer friz Haas Mills 9 09-22-2008 05:00 PM
wanted router frame to refurbish Art Ransom Want To Buy...Need help! 0 09-06-2008 09:51 AM
Wanted: Used CNC Router Wayne, MI rwhit1962 CNCzone Club House 1 12-13-2007 08:50 AM
IMService Servo CNC Router review buscht Commercial CNC Wood Routers 12 08-17-2006 03:57 PM
K2CNC Router Review (first Look) CNCadmin K2CNC 83 05-03-2005 05:31 PM
