Old 11-24-2008, 04:36 PM
mmorton is on a distinguished road
Lightbulb Digitizing with a CNC router????
Can anyone tell me if it is possible to use a cnc router to plot points in order to re-create a part? I work on several small parts that are not very complex but in order to cut them out with our CNC router, our engineer has to draw a 2D sketch that I transfer into G-code to use with WinCNC. I am wondering, if I have a sample part I can lay out on the table if it would some how be possible to plot it using the router itself. Our engineer is swamped and usually takes 2-3 weeks to get me a drawing. Any input is apprectiated.
Old 11-24-2008, 09:54 PM
lsalme is on a distinguished road
Digitizing on a router
I was looking up this topic the other day. The Artsoft Mach 3 website has info for building a touch probe which can be used in Mach 3. Also you could probably use a camera for digitizing.
Here is a camera setup used in Mach.
http://www.9w2bsr.com/2008/02/webcam...and-mach3.html
Old 11-26-2008, 06:28 AM
blackbeard52 is on a distinguished road
Actually there is a point cloud plugin on Mach3 site... it allows you to use a touch probe to do just what you want. Read through the forum and learn from the users on how its done... www.machsupport.com....
Just noticed you are using Wincnc...Someone chime in...I dont think you can use the trial Mach3 for pointcloud......
Bob
Digitizing probe for cnc Router irk3 Digitizing and Laser Digitizing 4 04-25-2010 03:28 AM
Newbie- Need digitizing help g450pilot DIY-CNC Router Table Machines 4 05-02-2008 07:39 PM
Digitizing raygarrett1 Employment Opportunity 3 05-30-2005 11:31 PM
Digitizing Michael M AjaxCNC Control Products 9 01-18-2005 04:14 PM
3d Digitizing WORKALONE Digitizing and Laser Digitizing 0 04-13-2004 03:23 PM
