Old 11-23-2008, 08:51 AM
stk2008 is on a distinguished road
My home made cnc in progress
Hi all for the past year I have been designing and making my very own cnc
router and have finaly got somthing to show for it I have very nearly made itand would like some help on what stepper motors to use I was looking at this kit http://www.motioncontrolproducts.co....products_id=58 and am not sure if they are a good make and if they have the power to move my gantry. The size of my cnc is about 1m by 0.8m working area the moving gantry is about 35kg rather heavy tbh pics to follow shortly.
So to recap asre these motors,power supply etc any good are the a well known make and from the spec sheet of the motors etc have they got a fair bit of power?.
p.s just getting photos now brb.
thanks in advance dan
Old 11-23-2008, 09:14 AM
photos
ok here are some pics
ID:	70276   Click image for larger version
ID:	70277   Click image for larger version
ID:	70278   Click image for larger version
Old 11-23-2008, 11:06 AM
Kipper's Avatar
Kipper is on a distinguished road
@ 12nm they should be powerful enough to lift the router up I have over 2000 hours of use on my kit 110V drivers but same manufacturer.....Never heard a bad word about them.
Keith
Old 11-23-2008, 02:52 PM
cheers for the reply ok may order them up then do you know how easy it is to add another axis to that kit as I want to add a 4th axis to the bed to roatate table legs etc on.
Old 11-23-2008, 03:10 PM
Freff is on a distinguished road
Hi Dan
Your machine is looking good. I'm building one along the same lines as yours. The motors and drivers are the same as you intend to get.
I would very interested in some close up detail photos of your nut setup and bearings. I have yet to finalise a decision on precisely how I'm going to do it.
Good luck, and I look forward to see more of your build.
Tony
Old 11-23-2008, 03:17 PM
Unhappy
no prob freff when i get a chance I will take some nice close ups for you.
I am chuffed tbh its my own desighn I dident copy no plans and so far its great a few little probs but still.
one thing I have learnt im going to allways use fully supported rails through out next time less on the z axis cus no matter what u will allways get play in the end im hoping i get little play on the y axis when i cut should be ok
Old 11-23-2008, 03:26 PM
Kipper's Avatar
I have 4 axis' on my mill Dan....Only 3 drivers! Buy an extra motor and just plug it in when you need it.
Keith
Old 11-23-2008, 03:42 PM
It's good to design it yourself, self satisfaction is a confidence booster. Here is a couple of photos of mine. I'm in the process of getting some box section mild steel for the base, and somehow trying to figure a way of making "pockets in the side of the gantry for the bearings. I have bored some 1 1/2" round ali with Delrin pressed in to make the nuts. I'll see how that works out tomorrow when I thread them.
Tony
ID:	70336   Click image for larger version
Old 11-23-2008, 03:54 PM
kipper I thought you needed one driver per motor i want it to be a 4th axis indipendent not copy one of the other axis is that what you way does?
Old 11-23-2008, 04:04 PM
MrWild is on a distinguished road
Spending twice as much as you need to. Chopper drives aren't as nice or efficient as PWM drives. You're also not getting mid resonance damping. For 1/2 the cost of the drives and breakout board, a GeckoG540 would work much better. Your router is also a good size for smaller motors. Those 34 frame motors are HUGE and much more than you need. A problem of those large motors is that they are slower. Yes, they will work, but smaller is actually better for your needs.
  #11   Ban this user!
Old 11-23-2008, 04:08 PM
allrighty pwm,chopper you have lost me maybe I should look at the electrical side more the mechanical side is easy for me the building of the machine so to speak I suppose I should go and studdy on what others have used for same machine size etc.
smaller would be better then the ones I want are over kill well that good to hear as I thought my machine was way to heavy.
so where could I get a complete kit ready to plug into pc remember I live in uk
cheers all.
  #12   Ban this user!
Old 11-23-2008, 05:29 PM
Kipper's Avatar
So can you explain the difference between "chopper" and "PWM" please I need to know?
(Also you forgot the bit about "morphing to full step" for the 540)
stk2008 can you use 4 axis' all at once? I only use A Y Z for round objects.
It needs to turn feed and cut...=3?
Keith
My home made CNC . C. J. Hung. DIY-CNC Router Table Machines 36 11-22-2010 12:08 AM
Home made ATC pstockley General Metal Working Machines 21 11-09-2009 05:12 PM
Need Help!- Bridgeport Interact 1 MK2 some progress made BrianP Bridgeport and Hardinge Mills 19 08-15-2008 05:17 PM
Home made EDM RFERG43 CNC Plasma and Waterjet Machines 18 08-29-2007 07:18 AM
Home made CNC mill (and some products made by it) gcamlibel DIY-CNC Router Table Machines 23 04-05-2004 06:54 PM
