#61
| 1: I would use 5amp, it will give you a bit of leeway. 2: Use the glass type used in cars. Start with 3amps they should be ok. Should they blow go up to the next size. 3: 20-22 gauge should be ok for everything after the controllers. 4: If I remember correctly there is no earth wire from the power supply to the controllers, only the pos & neg DC to the controllers. From the mains outlet there should be 3 core connected to the appropriate connections on the power supply. 5: Not sure what you mean. Each motor should be wired independently into its controller. 6: Ideally it should have it's own supply as the USB volts are not always sufficient. I'll check later to see if yours has. Tony |
#62
| hi freff cheers m8 ummm i thought it should have 3 core from the mains to the power supplies but in the drawing it deff shows only two core from mains then from the earth of the power supplies (green wire) it shows it going to the controller case as earth?. u saying to use a 5amp fuse from the mains to the power supplies?. when i say how to wire motors i did mean seperate (one on each controller) i meant bi-poler,series,perralel?. cheers |
#63
| The drawing is a bit misleading. Yes you need a 3 core cable from the mains to the power supplies. You don't need an earth from the power supplies to the controllers, besides I don’t think there is any connection on the chassis to connect to. If you decide to put all the electrics into a metal box when you finished then you can earth the box from the earth connection on the power supply. The power supplies don't draw 13amp from the mains; therefore any problems with the supplies may result in damage or worse before the fuse blows. 5amp would blow quicker. Join the motors wires in parallel. Be sure to double check that you join the correct two wires together when making up each lead for the controller. It's a simple error to make which will cause endless problems later. Hope that doesn’t sound patronising. Tony |
#64
| great well i thought i was being a complete noob i was sure it was only showing 2 core mains when i thought it should have been a 3 core. cheers m8 ok will get the wire from maplins this week as im in a pickle now me cambelt went on me car last week so moneys is tight.will keep u posted m8 thanks again |
#65
| not much of an update but my garage is now coming on nice ive only insulated the ceiling and painted the walls should be ok for abit as im in a real need to get me machine up fast but i cant untill me garage is converted into a some what workshop space. will post pics of garage etc soon. p.s ive allso now made the router mount for z axis but in the future i will use a stepper motor for the spindle drive will be able to tap things out then to . |
| My home made CNC . | C. J. Hung. | DIY-CNC Router Table Machines | 36 | 11-21-2010 11:08 PM |
| Home made ATC | pstockley | General Metal Working Machines | 21 | 11-09-2009 04:12 PM |
| Need Help!- Bridgeport Interact 1 MK2 some progress made | BrianP | Bridgeport and Hardinge Mills | 19 | 08-15-2008 04:17 PM |
| Home made EDM | RFERG43 | CNC Plasma and Waterjet Machines | 18 | 08-29-2007 06:18 AM |
| Home made CNC mill (and some products made by it) | gcamlibel | DIY-CNC Router Table Machines | 23 | 04-05-2004 05:54 PM |
