Old 11-22-2008, 03:42 AM
andycorleone is on a distinguished road
Mach 3 Configuration Steps per unit
Hi, I'm really confuse with this, I read the manuals and the videos but can't solve it.
1)My lead screw are: 1/2-10 ACME Lead Screw
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=330287884711
2)Micro step is set to 1/4 in drivers
3)Motors are NEMA 23
4)The motor is are directly coupled to the lead screw
which "Steps per" I should use in mach 3?
Should I use Inches instead of mm in the "Default Units" becasue of my setup?
Many Thanks
Old 11-22-2008, 04:17 AM
Khalid's Avatar
Khalid is on a distinguished road
Steps/Unit= 200 *4*10=8000 steps/unit
Old 11-22-2008, 04:27 AM
TOTALLYRC is on a distinguished road
Post Steps/per unit calculations.
Many Thanks
Asuming a 200step per rev motor.
10tpi x 200 step per rev of the motor = 2000full steps/inch. x 4 (1/4 steps) = 8000 1/4steps/inch.
divided by 25.4 mm/inch = 314.96062992125984251968503937008 steps/mm
If my math is right, and I am sure somebody will correct me if I am wrong.
There is also a utility in Mach3 that says input a distance and then measure how far it actually went. It calculates the proper steps for you. It is under one of the set up tabs but I can't remember which at the moment.
Old 11-22-2008, 07:24 AM
Thanks look like it works I did a circle test with 8000 and measured and to me is perfect.
Many thanks
Old 11-22-2008, 08:55 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Very good! Now you need to measure the ACTUAL axis travel vs the travel that Mach indicates. If these are not equal, (due to mechanical inaccuracies) then you will need to tweak the steps up or down slightly. UP if distance traveled is LESS than indicated, DOWN if distance is MORE.
CR.
Need Help!- Steps Per Unit” in “Axis Calibration Problem Mr.Chips Mach Mill 6 09-02-2008 09:45 PM
Mach3 Steps per Unit (Belt transmission) vdKroon Mach Software (ArtSoft software) 5 02-18-2007 05:42 PM
Steps per unit is all messed up??? mwalach Mach Mill 2 02-18-2007 12:50 PM
Set-up / Steps per Unit / Threads per Inch adda Mastercam 2 01-15-2007 05:29 PM
Taig MicroMill 2000 and Mach 2, Steps/Unit?? JV11 Mach Software (ArtSoft software) 2 09-25-2006 10:32 PM
