Ok so i found a machine that i liked and started on the hardware. The machine is from this site www.cq.cx/pcb-router.pl . I am having a few probs programming the .cpp files he has supplied i was curious if anyone knew any software i could use with this? or if anyone could help me compile the cpp files. |
| If you've never compiled something before you might consider going with something that's pre-compiled for you. If you want to compile it and are having trouble, the best person to talk to is the guy who wrote it. You'll need to get a compiler first since windows doesn't come with a compiler built in like Linux does. There are other freeware preview tools available as a binary, pre-compiled, distribution. CNCSimulator comes to mind. As the site you linked to says, Eagle CAD has a free version with some limits on board size, and there's a user script, also free, that will make the gcode you need to isolate the traces. ...Then you'll need another bit of software, Controller, to interpret the g-code and generate the pulses and direction signals on your parallel port....Sorry if I'm repeating information you already know. I run my router with EMC which is Linux based so I can't really give any good recommendations on Win based controllers. User script, isolation routing gcode tool: http://www.brusselsprout.org/PCB-Routing/ Eagle CAD: http://cadsoft.de/ Good Luck! |
| Build Thread- Building a CNC Router; by someone who can't build a CNC Router | Womble | DIY-CNC Router Table Machines | 2 | 09-27-2008 08:51 AM |
| Newbie- Does anyone own a EZ Router Machine? Plasma or Router. | sngatlanta | Commercial CNC Wood Routers | 30 | 04-11-2008 11:48 AM |
| Router Using 3/4" MDF (first router build) | eguy208 | CNC Wood Router Project Log | 33 | 04-11-2008 11:33 AM |
| Using a router for the 1st time. Need advice of cut speeds, router bits etc. | Apples | DIY-CNC Router Table Machines | 19 | 09-23-2006 04:33 PM |
| Surfcam PP for Isel router / Precix router | IvanTochev | Post Processor Files | 2 | 05-12-2004 01:27 PM |
