Just a quick question. Can a well made CNC machine using servos and a good router, but built from MDF, handle milling Alum? See, I was thinking of ordering high-quality parts (Servos, Gecko drivers, Ballscrews and Linear Rails) for my machine, but saving some initial cost by building it out of MDF. I have a few reasons for this: 1) MDF is easy to work. 2) MDF is cheap enough that I can tinker with the design. 3) If the MDF machine can cut Alum, I can use it to remake the machine from Alum once my design is final. So, any thoughts? |
| Maybe, My machine was bought. Made of tubular steel frame for stand and aluminum plate and extrusions for the machine itself. I usually use it for contouring graphite for glass molds. As sturdy as it is, it's still a challenge to get good work in aluminum. No match for a proper mill. |
| The machine is too light. The position accuracy or motive power is not a problem, but vibration is. If I mill aluminum plate with an appropriate 1/4" end mill, I can get pretty good cuts. I can't hog anything and the swirl marks in finish cuts is more than you would get with a good mill. The router bearings aren't up to the job, and the 12" Z axis isn't rigid enough when extended. I have to use a tall fixture block to raise the workpiece so the Z axis is only hanging down a couple of inches. The uprights are of 1" aluminum plate, the crossmember is 6" square tube. The base plate is 1/2" aluminum plate with 5/8" plate rabbited on edge and screwed to the base to form T-slots. The ballscrews are rolled. I cut dry just to keep the machine clean. I could probably get better results with proper coolant. I don't think you would want to use coolant with an MDF machine. |
| Many of the members here have milled aluminum with their MDF machines. Balsaman is the only one that I can think of off hand. Good luck.
__________________ Stop talking about it and do it already!!!!! (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Hi. This is no claim to fame but I did most of my hard aluminum alloy cuts on a machine that was held together with a couple of 2x4s. I noticed that using the right cutting tool for aluminum, slow feedrate and, yes, WD40 meant that there was little load put on the frame. Now that I switched to 8020 extrusions, I'm cutting the same alloys at a much faster rate and the edges come out much smoother. Not to knock off MDF but when I cut it, I get tons of a fine 'talc' that gets everywhere including the screws, rails, lungs, etc. Check the 8020 forum out and post your frame requirements - maybe they can help you as they did with me. Later, JR |
| I don't have a problem keeping the speed down to save some money initially. Once I start selling some parts, I can always upgrade the machine. So MDF will work if: 1) Keep the ipms down. 2) Use some sort of cutting fluid! 3) Use the right bits (and keep them sharp!). |
| I'd say so. See the video here when I cut my router's base. I used a plain PVC clamp I got from the hardware store to hold the router while cutting the real holder. Because the whole setup it was so flimsy and my then router was only 1/2 HP, I did that cut very slowly. But, it worked. Regards, Julio |
| Cut the MDF to create an CNC machine. | samsagaz | WoodWorking | 6 | 07-22-2008 11:20 PM |
| My First CNC Machine, Mr. Chips | Mr.Chips | DIY-CNC Router Table Machines | 81 | 02-10-2007 09:04 AM |
| MDF CNC Machine Progress | victorbl | CNC Wood Router Project Log | 61 | 03-26-2006 09:39 PM |
| new cheap mdf machine | Hobbiest | DIY-CNC Router Table Machines | 36 | 02-24-2004 10:54 PM |
| Machine Tool Camp 4'x8' VS Cad Cut CNC 4'x8' Router | Trimix | DIY-CNC Router Table Machines | 6 | 12-18-2003 01:49 PM |
