Old 11-17-2008, 07:07 PM
slammedxonair is on a distinguished road
I need some help. Dont know what to do.
Well heres the story. Massajamesb get me interested in building my own machine awhile back. I started buying the parts he told me to get. Well I ended up picking up a dynatorch plasma table. But I would still like to build a router table as well for doing HDU and wood signs. Needless to say I have no idea whatever happened to him his last visit to the site was almost a year ago and he has not returned any of my emails.
Anyways if i can with out too much more of an investment would like to build a small machine that the table size could be upgraded in the future (my dynatorch takes up alot of my extra space), or I just want to sell the parts I have now. here is a pic of everything I have allready bought I really dont know how to hook any of this stuff up or how it interacts with eachother. Thanks for any help at all.
Old 11-18-2008, 01:47 PM
So does anybody know how I would hook this stuff up and what I still need as far as the electronics are concerned? I know I need a power supply but is that it? I went over James old email i had saved but there was nothing there I didn't remember him talking about. Thanks
Old 11-18-2008, 11:00 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
overall it looks like you need to finish soldering your board and find a power supply .
your relay board will not connect to the drive board unless you can find some kind of splitter or run a second parallel port , to be honest what i would do is put that driver up on ebay and get some gecko's , Ive got the gecko 201 drivers and the same relay board as you and i absolutely love the combination , they have a sale on right now and their smaller drivers are pretty cheap
if you want a good deal on a supply then this may be a start , ive got a couple of these industrial supplies for my setup and they work nicely , if you look up the price of them its sick http://cgi.ebay.com/POWER-ONE-POWER-...1%7C240%3A1318
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 11-23-2008, 02:14 PM
Ok so is the following how everything should normally get hooked up:
PC into relay board, from there it goes into the driver board, and then into the motors?
Also what do you mean by a splitter? I would really rather try not to buy anything more than I absolutly need to to make this work. If I do build the machine I want it to be a budget build just for something different to do, which would also get used to make signs as well. I have pretty much all of my money tied up in my other metal fab equipment and the Dynatorch. Would I be able to build this with less than say another $200 into it? I allready have a router I can use. Thanks
Old 11-23-2008, 02:34 PM
ger21's Avatar
What were you going to use the relay board for?
If you just want to get up and running, all you need is a power supply. PLug the HobbyCNC board into the parallel port, and wire up your motors and power supply to it. That's it. If you want to use the relay board to turn things on and off, then pick up a $20 PCI parallel port card and add it to your PC. The relay card would plug into this second parallel port.
Old 11-23-2008, 03:10 PM
I really don't know lol Thats just what James told me to order when he was helping before he dissapeared off the site and stopped responding to emails. It might have been for the plasma because I was going to build a hybrid machine before I got my dynatorch.
So if a power supply and a small fan is all I need to get the electronics working than thats great news. Now I just need to figure out the power supply and all that pully and slide and gearing stuff lol.
Old 11-23-2008, 03:57 PM
ProDrawerCom
IQChallenged is on a distinguished road
"I would really rather try not to buy anything more than I absolutly need"
Sounds to me like this just isn't a good time for you to build. I'd either put the stuff aside or just sell the stuff. Personally I think it's better to sell, use the money, but new stuff later. When you get ready to build contact me or someone to line out a step-by-step of going from a box of mystery components to a running machine. I've been where you are.
www.ProjectCNC.wordpress.com
Old 11-23-2008, 04:07 PM
dertsap's Avatar
Gold Member
the electronics is usually the bulk of the cost and you already have that .
slide cost will be minimal if you use the diy skate bearing slides and if your building an mdf machine then a chunk of mdf is $20
you can use ready rod for leadscrews which is dirt cheap until you can upgrade
the relay board is just to have the computer control you router on/off rather than having to turn the router on manually ,its only gravy and its not necessary
Old 11-23-2008, 04:29 PM
Yea I had thought about selling it but I also thought about how much more money I could make if i could do routing/ engraving as well and I think that has out weighed the issue. Also thanks for your understanding in where I'm at. I'm very mechanically inclined and I know I can build this I just don't know what I need to do lol. Thanks
Old 11-23-2008, 04:37 PM
I probably dont need the relay board now because the router would be on most of the time it's running any ways, and the relay board was more important for the plasma system.
I guess I understand the basics of how the machine opperates because of the dynatorch but that is also a servo system. And also the majority of the cost is in the electronics and then drive system.
I need to figure out if i should go with a lead screw drive, rack and pinion(i think that is whats on the dynatorch) belt drive, or a chain drive. Would anybody be interested in letting me know the advantages / disadvantages of these drives and what all is involved in gearing it down?
Also I'm not sure what size table I want to build yet either if that factors into any of the drive systems as well. Thanks again.
  #11   Ban this user!
Old 11-24-2008, 01:58 PM
Will this power supply work? http://cgi.ebay.com/CNC-STEPPER-MOTO...742.m153.l1262
This is the driver board I have i think unless they have updated it since I bought mine http://www.hobbycnc.com/products/hob...er-board-kits/
the power requirements are the same that are listed on my instruction sheet but I'm not 100% on what all of that means.
  #12   Ban this user!
Old 11-27-2008, 07:59 PM
bump
New Machine Build- dont know where to begin dragon23 DIY-CNC Router Table Machines 10 01-05-2009 11:47 AM
Need Help!- Need Help lathe dont start. Playback General Metalwork Discussion 0 09-30-2008 11:31 PM
I've Been Scrounging but dont know what i have!!! swiftden Stepper Motors and Drives 7 08-08-2005 11:01 AM
Things I dont like about ver 19 and 20 carbidecraters BobCad-Cam 1 04-16-2005 02:44 AM
I just dont understand... freezer General CAM Discussion 19 02-11-2004 12:55 PM
