#98
| looking forward to seeing you guys' cuts! actually, no.. that'll probably make me jealous ![]() the more I look at it, the crappier my build seems. I think the first chance I get I'll rebuild the gantry and get a new router. actually, while running a test today I noticed that my router (bought used for $25..) suddenly started making a different noise, and when it spun down it made kind of a clicking noise. That kind of makes me nervous. what happens when a router dies? Does it go up in smoke/flames? Anyways I'm keeping a finger on the estop now |
#99
#100
| Jack, how about some pics of the final machine? Crappy or not, you've made a CNC machine and that's something to be proud of. It cuts, it works, it's a cnc -- what more would one ask for, heh. With this machine, it'll be easier for you to design your next. A good example would be Joe's 2006 CNC. Now that you can cut out your own parts, it's a piece of cake. But, do not bash at your machine, no matter how not "beautiful" it looks (I personally think it looks great (and very very simple) from the earlier pics). You've worked hard and I, myself, am very pleased that you've gotten this far. I've been following your post since the beginning. As for the router, I don't know much about machinery, but I do know that it is probably not a great idea to be working with an equipment that can injury and/or damage to personal property that is unstable. I bought myself one of these: It was on sale when I got it. Here's one by itself: A lot of people use this one because it's the quietest in its class. I got the kit version with two bases just because I am sure I will need some manual work later on and since it was on sale, it seemed like a great idea. I've already used the plunge base to cut out holes for a gigantic cat tree that my wife was making. -BK |
#101
It slung a few wires off the armature into the field core. That unusual sound means something. It could be bearings, bearing to case slippage, or something else, but it's almost guaranteed that it will get worse.CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
#102
| I'll upload some pics when I'm finished the whole thing. Right now I'm more concerned about finishing this robotics project on time! The router's been working 5 hours straight now without dying, so I'm pretty hopeful that it'll last for a while. I also burnt my first bit to death! I tried to do a 3d profile and bit off more than I could chew in each pass, lesson learned I guess ![]() The second time around I tried light passes, quick feed rate and the bit seems to be holding up. But it's still charring a bit even though it's barely taking off any material in each pass. Any tips on avoiding bit burnout? |
#105
| enco sells 1/4" endmills. I've been told that the 4 flute ones I bought are not good for anything but steel, but since I've burnt my only 2 flute spiral bit that was my only option.. I'm not sure what the difference is between an endmill and a spiral bit, but I assume spiral bits are better for wood since they're designed for that kind of material. |
#106
| Buy solid carbide router bits. End mills are not designed for the speeds a router turns and they are used with coolant on mill. Router bits are designed to run at high speeds with nothing but air to cool them. Also looks like you are cutting mdf which is hard on any bit. http://centuriontools.com/ http://www.hartvilletool.com/category/630 http://ballewsaw.com/ |
| Newbie - To build or not to build Router/Plasma Table | dfranks | CNC Plasma and Waterjet Machines | 10 | 04-07-2011 11:16 PM |
| NEW BUILD: PVC as a build material | Smiler | DIY-CNC Router Table Machines | 12 | 11-13-2009 04:57 PM |
| New Large Table Build in Houston, TX (Build Log) | anitel | Plasma, EDM and other similar machine Project Log | 12 | 12-30-2008 02:45 AM |
| New here looking for help on CNC build | JohnBee | DIY-CNC Router Table Machines | 4 | 10-03-2006 05:03 PM |
