  #13   Ban this user!
Old 03-17-2009, 09:20 PM
johnmac's Avatar
johnmac is on a distinguished road
I don't have any experience with servos, but I think there are only 2 for the motor, and 4 for the encoder. Thats the reason I questioned the 8 wires. You may be correct about the unused pins.
Looks like your going to have a nice machine.
John
  #14   Ban this user!
Old 03-18-2009, 01:09 PM
gavztheouch is on a distinguished road
Just checked my motors, I have 5 wires on the motor (2 black 2 red and 1 earth) and 6 on the encoder? Is there any reason these motors and encoder will not work with the Granite Devices driver (VSD-E) or a similer Gecko Drive
  #15   Ban this user!
Old 03-18-2009, 02:42 PM
johnmac's Avatar
I don't know anything about the Granite product, but you can download a PDF of the Gecko driver at their web site www.geckodrive.com. You will probably need to know which wires do what on the encoders.
The only reason I know anything at all about servos is I have given some thought on changing my steppers to servos.
John
  #16   Ban this user!
Old 03-19-2009, 03:51 AM
Ok, it appears that Both Gecko and Granite devices are both limited to 80v while my motors are 140v.
Due to the weight of the machine im not sure I would get away with smaller motors that would run at 80V?
Could I gear the motors down to make the load easier and half the max speed?
  #17   Ban this user!
Old 03-29-2009, 01:00 PM
Managed to test both motors with a 12v battery, so far so good they both turn smoothly.
Next step is to test the encoders then directly mount them onto the shaft at the rear of the motor. The flanges on the encoders are much to big too fit the mounting bracket on the motor so I will need to make up some reducers mounts to make them fit. The challenge is going to be keeping the two shafts running parallel with each other.
Luckly the two shafts both measure 6mm which seems to be a common size and couplings seem to be easily found, although prices seem to vary massively like $140 for a 6mm to 6mm coupling?
Will these Maplin brass coupling be up to the job? Its the brass inline connectors on the link below.
http://www.maplin.co.uk/module.aspx?moduleno=9335
Video of the motor test.
  #18   Ban this user!
Old 04-21-2009, 02:11 PM
Here are some more pictures of the machine, now semi built in my own workshop.
Build Thread- Steel Frame CNC Wood Router CNC Rocks DIY-CNC Router Table Machines 12 08-11-2008 11:13 AM
First Router steel & wood. thetrick CNC Wood Router Project Log 13 04-15-2008 09:00 PM
Using steel instead of wood for construction ChristianW DIY-CNC Router Table Machines 1 07-04-2007 07:55 AM
1st Machine, Steel ,Overhead Gantry bradodarb CNC Wood Router Project Log 4 10-18-2006 02:05 AM
Milling Steel with a Retroed Wood Router whiteriver Commercial CNC Wood Routers 2 07-08-2005 06:27 AM
