| router will cut aluminum , i usually give a squirt or two of chainsaw chain lube to avoid a melt down ,its thick enough that it sticks and doesn t get blown around ,
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| you lube the router or the bit to the aluminum (maching oil) also if i do make one to cut aluminum (that is all i would be cutting with it) i should put in like a air nozzle? are there routers that run a little slower speed that would be more suitable to cutting aluminum? thanks again mike |
| the lube is to lubricate the tool , most diy routers probably wont do for constant cutting of aluminum basicaly due to rigidity and router motors are made to cut wood , air nozzle wont help on aluminum , if all you plan to cut is aluminum why not buy a small mill , you can buy a mill for what it will cost to build a router solid enough to do what you want to do
| Hey hellbringer, We've been using our router for everything non-ferrous. Alum, plastics, fiberglas, and wood all cut great. For coolant we're using a cool-shot system that takes compressed air and cools it to about -20 or -30. It works great for everything except 1" and thicker thick alum. then we use WD-40. Once the tool path gets deep the air has some issues getting into the bit. We did a build log on the DIY router thread about a year ago. It's under Med-Pac's new router. Here's a few pics of it in operation and the parts we've been cutting. Mike |
| 8020 table top instead of aluminum slab? | analogman | DIY-CNC Router Table Machines | 8 | 10-22-2008 09:37 PM |
| Using a CNC Router on Aluminum | emarthinsen | DIY-CNC Router Table Machines | 2 | 02-20-2006 07:47 PM |
| has anyone seen an aluminum table for an old J-head bridgeport mill? | xhardwaremanx | Bridgeport and Hardinge Mills | 2 | 11-19-2005 03:06 PM |
| Slotted aluminum table | PEU | DIY-CNC Router Table Machines | 11 | 11-09-2005 10:34 PM |
| aluminum table tube | dgalaxy | DIY-CNC Router Table Machines | 2 | 05-09-2005 08:23 AM |
