Well the machine tested out great over and over, I even ran it for an hour the first day just to check for issues. No it will run for just a few and go into e-stop. sometimes it's only half a sec and it etops. Other times it will run for 30 seconds or so the e-stop. What in the world is going on? Evan
__________________ Evan. "You're making WHAT?" |
| What controller are you using? And did you wire the limit switches and E-stop NO, (normally open)? Could be shielding issues, easiest fix is to wire the limit swithes and E-stop normally closed. Most people will preach shielding and grounding... NC is the easiest fix. |
| Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| New Machine Build- EMC2 E-stop parallel port pinout and E-stop loop | GreenLead | LinuxCNC (formerly EMC2) | 12 | 08-03-2010 01:05 PM |
| Problem- Bridgeport stopping in cycle | pinkminky | Bridgeport and Hardinge Mills | 3 | 09-30-2008 08:07 AM |
| Stopping and Restarting in a Program | Dugg | Haas Mills | 5 | 01-14-2007 04:32 PM |
| Help with selector switch wiring issue (***actually a motor issue***) | BEDFORD | Industrial Hobbies (Support forum) | 7 | 04-07-2006 04:19 PM |
| VF2 keeps stopping | donj1 | Haas Mills | 16 | 08-11-2005 11:09 PM |
