  #13   Ban this user!
Old 11-11-2008, 07:21 PM
GM Barton is on a distinguished road
Red face Z axis motor
After testing everything we could think of, it turned out to be the Z axis motor. We replaced the motor and have had no problems since.
Previously we had a dual router configuration and I think the excess weight of the routers put undue stress on the Z motor. We're cutting with a single router now, but when we go back to dual axis, I'll look into getting a spring or air cylinder to help support the weight and/or a bigger stepper motor.
Thanks for all your suggestions!
- Greg
Tags
anaheim, problem, wincnc, z axis
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
dropping tools need help porkchop21 Bridgeport and Hardinge Mills 7 02-02-2007 10:28 AM
Voltage dropping Resistor? dmgdesigns General Electronics Discussion 4 09-22-2004 10:32 PM
